civic vids from a roll
Old May 7, 2005
brianturbocivic's Avatar
brianturbocivic is an unknown quantity at this point
These are a couple vids of me running through the gears. my buddy is in a dakota filming not racing
this is first and second gear pull
1st to 2nd pull
this is just from a roll in second
2nd roll
Old May 7, 2005
ThsUserNmIsDumb's Avatar
Currently boosted at 0 psi.
ThsUserNmIsDumb is on a distinguished road
Pretty quick... I want more!
Old May 7, 2005
How much psi are you running? What's your setup?
Old May 7, 2005
6 psi untuned setup is custom from california t3/t4 garret rsx type s injectors alcohol injected
Old May 7, 2005
Hypnotized's Avatar
Hypnotized is an unknown quantity at this point
omg... I want turbo. That's so nice...
Old May 7, 2005
S2000man01's Avatar
O RLY
I'm confused. You had that video of you and an SRT4 at 16psi, and you pulled.
However, that would mean that your car is into the 13's.
Taking a car from high 15's to 13's is going to take more than 6psi on a t3/t4 with injectors..... not to mention you're untuned?
just wondering if you could explain your setup more? what size injectors? alcohol injection has a cooling effect which will give you a similar effect as having an FMIC, so it's not a ton of horsepower at the moment. Otherwise you don't have enough boost right now to make any other difference.
Old May 8, 2005
Not Sure What Size Injectors But They Came Out Of A 03 Rsx Type S, Apexi Fuel Pressure Regulator, In Line Fuel Pump, Spraying Alcohol Under Boost, Custom Manifold, Full 2.5 Inch Hp Racing Exhaust, No Cat Or Resonator, Electronic Boost Controller, Turbo Xs Bov, Fmic, Nothing Special It Hasnt Been Dynoed Yet Im Anxious To See What Kinda Hp And Torque I Got Right Now. Only At 6 Psi. Greddy E Manage Not Installed Yet. You Got The Video Though So Maybe Some Of The People That Were Talking Crap Will Calm Down Now
coupeciv
Exterior
Apr 23, 2015 06:48 AM
dooner24
Apr 14, 2015 07:51 PM
Elusiv1
Oct 8, 2001 03:44 PM
SILVERCASE
Sep 25, 2001 08:34 PM
pimpdakota
Jul 22, 2001 09:12 PM
