vibration at 80mph
Old Jan 20, 2002
bluecoupe's Avatar
bluecoupe is an unknown quantity at this point
vibration at 80mph
i rotated my tires at 10k miles and now it seems like my steering wheel is shaking a lot more than it used to (if it used to at all) at around 80 mph and up. is this normal after rotating your tires because the tires have to get a new wear pattern?
also, how often are you supposed to get an alignment?
and when i'm on the highway it seems like my car's steering isn't as nice at high speeds as it used to be, like its a little bit loose and the wind can blow my car around pretty easily, would an alignment fix this?
Old Jan 20, 2002
SlvrEX5spd's Avatar
SlvrEX5spd is an unknown quantity at this point
99% of the time you feel vibration in the wheel is because the tires need balanced, since they were in the rear b4 you might have felt a little in your seat or not much of anything at all......but i would advise just to get them balanced, should cure it
Old Jan 20, 2002
Bartkat's Avatar
If you swapped your tires from side to side and changed the rotaiton, then it will be squirrely for a while. Better to rotate just front to back AND balance too.
Old Jan 21, 2002
bluecoupe's Avatar
yea i didn't just rotate front to back. i rotated according to the pattern on tirerack.com for fwd cars.
Old Jan 21, 2002
mykel115's Avatar
mykel115 is an unknown quantity at this point
Two Word WHEEL BALANCING
Old Jan 21, 2002
strokelessone's Avatar
strokelessone is an unknown quantity at this point
2 more words......
avoid potholes
Old Feb 10, 2002
Todd1's Avatar
Todd1 is an unknown quantity at this point
vibration is bad at high speeds!!!!
Old Feb 10, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I remember I had a nasty vibration with my 91 Escort. Turned out I had 4 mismatched tires [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Feb 10, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
i had a really bad vibration in my 88 omni going 90 on a private road, the steering wheel was making a 70-90 degree arc. it needed an alignment, but at the time also had one low tire and one overinflated tire in front, once the tire pressure was fixed, it still had vibration, but nothing like it had before
Old Feb 25, 2002
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
Yup just have the wheels balanced. You did't notice as much as before because only one wheel needs to be unbalanced especially at 80 mph. So, if the tire was on the back of the car you probably wouldn't notice it. Since theres no device like the steering wheel to show you. The steering wheel is a very good indicator of unbalanced wheels.
mgrantaz
General
May 2, 2022 05:40 PM
jdawgzcivic
17
Feb 1, 2020 04:16 PM
Wariogamer
Sep 29, 2015 09:49 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
FistRock
Sep 4, 2015 08:00 PM
