02 Civic Sedan TYC housing with TSX HID projector, retrofit done!
I retrofit a TSX projector into a TYC housing for my 02 Civic sedan. Here is some pics to share.
Aiming my projectors
The TSX sit at the center
The back
of the orginal TYC
Next two are the TYC(not TSX) projector
TSX already in
Yes, I cut the back and rebuilt it, because I want to be able to aim the projector even after i seal the front len of the housing. BTW, with this design, i can rotate the projector. The projector is actually mounted in a piece of metal sheet. And that metal sheet is mounted on the back of the housing that i rebuilt. I made the three mounting hole of the metal sheet a little bit bigger so that i can rotate the projector.
I will post some more night pics later, night pic still in my dc.
The back
of the orginal TYCNext two are the TYC(not TSX) projector
TSX already in
Hey Louk was there any major fitment issues? Im torn between the TSX and Valeos .....how much cuttting was invovled? Any problems I should be aware of?
Yes, it involved a lot of cutting. I did cut the back and inside of the TYC housing, and the TSX projector. If you don't want to spend a lot of time, then I suggest you stay away from the TSX. With the valeo, you only need to swap the projector.
Boggie1688: I will take more pics and post later!!
aus10
Apr 13, 2015 09:26 PM
Lightman
Nov 10, 2001 06:44 PM
