bar brace set
Old Apr 24, 2005
Tomola's Avatar
Tomola is an unknown quantity at this point
Question bar brace set
hey pplz,
what do you think about this bar brace set off ebay?
also i'm not sure if it is going to clear my intake manifold? do you think it would go straight over, between the mani or motor side?
ID:	52434   Click image for larger version
Old Apr 24, 2005
robbclark1's Avatar
Retired suspension supermod.
Your intake manifold? You mean your intake. The intake manifold is the black plastic piece underneath the throttle body. They are generic parts, but will do a little bit. There are better parts out there.
Old Apr 24, 2005
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Has anyone installed a Neuspeed front strut bar and have problems with the brake pump vacuum tube getting in the way? Tomola, hope you don't mind me hi-jacking yer thread here but you got a very clear picture of the brake vacuum tube going from your intake manifold to the brake pump. Its the tube running parallel to the firewall.
Old Apr 24, 2005
robbclark1's Avatar
Not it sits above that. you should be fine.
Old Apr 25, 2005
Tomola's Avatar
just read the suspension FAQ - it's all good
Old Apr 27, 2005
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
i dont know about that specific intake, but in general, the Neuspeed front tie bar is the only one that will fit with aftermarket intakes. It's because where the intake comes up from the TB is exactly in between the two strut towers, so the Neuspeed goes towards the rear of the car, around it. If I were you I would go ahead and spend the money on the Neuspeed. Remember, you get what you pay for.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
honda.lioness
Aug 21, 2015 02:36 PM
7thgensurvivor
Jul 27, 2015 08:23 PM
carid
Wheels and Tires
Jul 20, 2015 07:15 AM
