d16 manifold
you will like the manifold. I love it. I used my d17 TB because it was bigger. Had to weld a flange on for that though. get good tools to port with. Also i used the d17 gasket as a template. Use the paper d16 gasket and cut it out. It seals better.
So... how does this fit on? You need to make an adapter plate or something to line up the head with the runners correct?
I'm to assume that if the Y8 manifold fits then any aftermarket mani also would fit with a similar modification process.
Looking at this down the road.....
Its arguable that the Y8 IM is the best SOHC IM honda ever made.
The turbo guys care because its metal not plastic, the plenum is bigger and the runners are straighter than the sink trap runners we've got.
cool, how much of a diff does that mani make n e ways?
it works fine without pnp there are a few holes that are off a bit. you can open them up with a drill. The runner ports are like a 16th of an inch off so you need to port them for alignment. skunk2 manifold is too long and hits on the firewall
jdh022764
18
Nov 3, 2015 06:44 AM
Mannimarco
Sep 7, 2015 10:01 PM
