Rear Window Removal
Old Apr 13, 2005
gnat1000's Avatar
gnat1000 is an unknown quantity at this point
Rear Window Removal
Now i'm sure someone on here has done this at some point. What all goes into the removal and reinstall. I'm going to glass a custom rear deck i'm making and it seems impossible without removing the back glass.
Old Apr 13, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
yea, i wanna do that just so i don't have to yell and scream when i get my new 6x9s
Old Apr 14, 2005
gnat1000's Avatar
lol well maybe not then
Old Apr 14, 2005
skipbarber's Avatar
well it is caulked in place. It's in the service manual, I think you remove the trims inside and out, then stick a metal wire or cord through a corner. Have someone inside and someone outside and work in a sawing motion all around until you have worked all the way. I think that was all..
Old Apr 14, 2005
R1Style's Avatar
I think you need a special tool to get the windows out.... someone might know what it is.
Anyways, instead of removing the glass, why don't you just take out the rear deck?
Also... instead of glassing it... you can get some plastic filler spray. It fills in the texture and then you sand it smooth. Once that's done you can just paint it and it'll turn out just as good as if you glassed it. Plus it's way cheaper and a lot easier.
Old Apr 14, 2005
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
the rear window is held in place with urethaene, just call a windshield company to remove/ install it for you, its usually pretty resonable
Old Apr 14, 2005
_Viper_'s Avatar
Yeah thats if they dont crack it..
no one will do that and not warn you of the possibility of it breaking
Old Apr 14, 2005
gnat1000's Avatar
I already have the rear deck removed and a few layers of sound deadening material installed. My plan is to glass over the top of it and make a custom rear deck. One of the first things I did with my car was remove the rear deck because I cant stand it.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
S.Klinck
Feb 10, 2016 02:19 PM
S.Klinck
Jun 11, 2015 10:27 PM
clockwerx
Dec 13, 2001 12:39 PM
BamBam
Dec 8, 2001 02:21 PM
