7" VGA Touchscreen in dash project *vid added!*
update! here is a mock setup video!
http://ekuai.net/images/dash.avi
here are some pics...just finished:
Step1: Cut
Step2: Bondo Hair
Step3: Bondo body filler
Step4: sand
Whats step 5? i heard something about a putty?
Step 6 should be primer? then sand then primer than sand?
step7 should be paint? what color should i use to match the oem? what grit should i use to sand in between?
im going to be making a carputer but till thats done ill just hook up the xbox for now...
Step1: Cut
Step2: Bondo Hair
Step4: sand
Electric Boogaloo...
The "putty" is a glazing/spot putty. It's used to fill very minor imperfections/air pores created by sanding. It's used to fill the minor stuff. I'd recommend sanding with between 300 and 600 grit sandpaper until you get a uniform surface. From there, put on one thin layer of the putty and let it dry. After it dries, sand lightly with said paper to knock down the high spots, spray a layer of a light colored primer (I prefer white or grey) onto it. After the light color dries, get a contrasting color (I like flat black paint or black primer) and spray a mist over that coar. Sand lightly until you have a uniform surface again. The places where the mist is left over are low spots. Continue this process until it's all even with no high places. Finish sand with 600 grit and paint (anything finer would smooth it too much and make the surface sort of waxy, the paint won't stick as well to something that smooth).
this is what i got so far
go here for more pics http://www.7thgencivic.com/forums/sh...d.php?t=195218
i need to relocate the lcd, because i can't see it on day time
Originally Posted by PopcornPlaya
Or just make it a tad bit more vertically flush. In other words, make it sitin there at a 90 degree angle perpendicular to an imaginary line parallel with the ground. That'll solve a lot of the glare issue you have with it being slightly tilted upward, folowing the line of the dash.
Originally Posted by thekuai
do i sand at all after applying the first layer of paint?
how much would you guys pay me to make an indash for you?
Originally Posted by kickercivic1
video is done it dark. Can't even really see the work.
granted this is my first time working with bondo/fiberglass but i gained a lot of experience from this project and the next fabrication is guaranteed to be better than this one (i sorta rushed the painting on this one)
if anyone is interesting in this service pm me
The video doesn't show the work at all. Just the screen. I'm a little confused, the pics above are not your finished product, are they? If so, then either my eyes are playing tricks on me or you couldn't possibly charge anyone for that. It looks all wavy and choppy. Plus, it looks funny that you didn't try to level out the two sides with fiberglass in order to acheive a balanced look. I do not mean to offend you, and if that's your first time using fiberglass you did pretty good - but you can't charge people for work like that IMO. Again, unless those either are not finished or look different than the project does in person.
