Drive Shaft???...
Balut Eating Champ
Drive Shaft???...
any of you guys know how to take the shaft off? i'm tryin to get my clutch installed by myself... I just can't figure how to take the shaft off, other than that I got everything figured... any help would really help... thanks...
Wanna see a donkey show?
The best way to find out is get a book. Always read up before doing any major job. It can never hurt to be informed. Btw let Us know how it goes I might be needing the same thing done soon. My clutchy feely softy.
Balut Eating Champ
i know from the inside, but just the drive shaft that kills me, I don't wanna put too much pressure on it that I might break something, plus I can't see the under the CV boot coz it's pack with grease, I don't wanna do something on a part that's not have anything to do with disassemble...
I'm thinking you take a crowbar and pop the whole axle out of the transmission. There should be a C ring holding it in, all you gotta do is apply enough force to pop it out of the groove holding it in.
Balut Eating Champ
hmmmm... online it said that it has this bolt that I need to unscrew then it should come off... but i'm not too sure if it applys to our vics... i'll try that... REP +1 to you bro!
yeah, just get a crow bar or a big flat head screwdriver and pop it out, usually you can just give it a good tug, but prying it out is the best way. when you pry it out, transmission fluid(gear oil) is going to come out of the hole. so have a pan underneith it. Good luck
ThE FaMiLy SeDaN
yeah mine came out w/ prybar.. no fluid came out tho... sometimes i wonder if my tranny cooler is allowing fluid to pass thru it... my dipstick shows tranny is full of fluid.. but the ends of the axles were dry...hmmmm
idk.. yeah they pull out.. my pass fell apart during braKE job.. lol they redid em...
btw if anyone needs d17 axles mended w/ k20 axles i can get it done...i found the CV king
Balut Eating Champ
i learned alot about my tranny today... and yeah, the tranny housing is not coming off
haha! I wasted 2hours trying to take em apart... clutch install is tomorrow i might do a DIY aswell... thanks for the help again guys
haha! I wasted 2hours trying to take em apart... clutch install is tomorrow i might do a DIY aswell... thanks for the help again guys Registered!!
Balut Eating Champ
Originally Posted by streetglower
no fluid should come out because you have seals sealing the fluid in the transaxle. If fluid does come out, you need to replace the seals. And when taking the axles out, be careful not to damage the seals.
so it's now wide open in my garage, i will put honda bond on it tonight and I hope it won't leat
but yeah, i knew my clutch was fvcked coz when i took the slave cylinder the fork was looser than 50yr **** star veteran's punani... anyway, i just purchased my new toys... universal joint kit for 15bucks, 60pcs air tool from powermate for 90 and 2gl air compressor for 55
it's gonna be awesome! dude, there shouldn't be a need for hondabond where the tranny bolts to the engine.....there's no fluid in there. just the clutch. there is a seal on the output shaft, but you won't be messing with that. and if you openned up the tranny housing.....that was not needed to replace the clutch. I'm not sure what you are talking about putting hondabond on???????
Balut Eating Champ
you where the tranny housing the keeps the transmission oil in? I friggin hammered the **** out of it coz I thought I need to take them off to get the bell housing out
anyway, yeah i figured that I don't need to take them off, lucky i didn't break anything...
the bell housing is not completely off yet, there's two more bolts that I need to take out before it comes off... will this thing drop on my head from underneath? how heavy is it? do I have to take my downpipe off will the engine falls off after I take the bolt from the engine mount and from the oil pan?
anyway, yeah i figured that I don't need to take them off, lucky i didn't break anything...the bell housing is not completely off yet, there's two more bolts that I need to take out before it comes off... will this thing drop on my head from underneath? how heavy is it? do I have to take my downpipe off will the engine falls off after I take the bolt from the engine mount and from the oil pan?
Xuhme
21
Aug 7, 2023 03:40 PM
chuffsy
May 15, 2015 12:50 PM
dosmastr
May 5, 2015 12:19 PM
smmahan
Apr 15, 2015 08:17 PM
