What's wrong now?! Good handling schocks, crappy softening.
Old Apr 6, 2005
norek's Avatar
(¯`·._.·[ I.Ç.E. BÕX ]·._.·´¯)
norek is on a distinguished road
Angry What's wrong now?! Good handling schocks, crappy softening.
Hey,
Here's my suspension, Tokico HP Shocks and Neuspeed Sport Springs. The handling on this combo is incredible. I can take some sweet, sweet turns with it.
But it's still not a smooth ride like some other people's cars I know who are lowered, or not lowered. Like if I hit a weird bump in the road, by car still feels like it got hit by a bomb. I like that my suspension is all stiff now, but I don't like how the new shocks don't absord that much impact on the roads.
Can something like the bushings be changed to fix this, anything else?
Old Apr 6, 2005
teampointless's Avatar
Ultimate Member
Possibly springs with a different spring rate to change how the load is handled? I don't really know suspension that well, just an idea...
Old Apr 6, 2005
stlblues13's Avatar
stlblues13 is an unknown quantity at this point
There are so many things to consider here. For example, what wheel/tire size are you running? Is the aspect ratio as low as your friends who are lowered? How low are they compared to your car? Same kind of car? Same kind of springs? The point is, unless you are comparing apples to apples it is tough to say there is something wrong with your ride. Any lowering springs are going to give you a more firm ride than stock.
I have the exact same setup as you and I can tell you I notice a big difference between my 17s and my stock wheels. I also have noticed that it depends a lot on what kind of bumps you are hitting. Some are worse than others - depends on how sharp they are.
Old Apr 6, 2005
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Its hard to have good handling and a soft ride at the same time. You have to compromise one for the other.
Old Apr 6, 2005
nindoo's Avatar
Why is my vagina bleeding?
BMW has it, but those cars cost an arm and a leg.
Old Apr 6, 2005
I ment in terms of a 7thgen but good point.
Old Apr 6, 2005
Zzyzx's Avatar
Autocross Junky
^those BMW's also have a good 1000LBS on us.... which accounts for much of the "Comfortable ride" part. Basic physics... F=MA (Force = Mass X acceleration) or alternatly A = F/M (Acceleration = Force / Mass).
Heres how this works in to the ride quality part...
A car that weighs more will inherently ride better simply because that chassis will not react or be affected as much by bumps then a Lighter car would. Even if both cars handle simmilarly. example, Take two cars, one weighs 500 LBS the other 1500 (1000LBS difference) Both cars hit a bump that creates an upward froce of 100N. The acceleration upward created by this bump would be approximatly how "rough" the bump would feel. On the 500 LB car, the acceleration would be (A = 100/500) A=.2 (Not sure if it would be Meters/second or what not but thats not important) on the 1500LB car A=100/1500 = .066666.... Signifigantly Less then the 500 LB car... See? The heavier car would react less to the bump, giving a smoother ride.
Old Apr 6, 2005
^^I was gonna say that but I was to lazy to type it all. jk jk
zzyzx owns all haha
Old Apr 6, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
Id definitely agree with zzyzx.
ACura TL with Tein SS would "ride" (feel less bumpy over the same bumps), then a 7thgen with Tein SS.
I know this to be true from personal experience.
Old Apr 6, 2005
nindoo's Avatar
This is probably a difficult question to answer. If you put performance shocks on the 7th gen does it react better to bumps than the stock shocks or does it feel like the car is gonna crack in half everytime you hit one. I'm going to be riding on stock 185 65 15 firestones. Right now for winter I have 185 70 14s and the ride is much stiffer than it is with my oem rims and tires, it always feels like the car is gonna crack in two when I hit a bump with these tires.
Old Apr 6, 2005
anibal's Avatar
anibal is an unknown quantity at this point
I know it's not important for sample purposes but, you need to make correction in your units, you're dividing N/lbs = (kg*m/s2)/lbs... convert the pounds to kg so it will give you acceleration in m/s2, or convert N to Lbm*ft/s2 to get acceleration in ft/s2.
Old Apr 7, 2005
Zzyzx's Avatar
Autocross Junky
Thanks! I loved physics in school... and I could comprehend concepts and such... just most of the math was beyond me. (Not to mention its been 7 years since my last math class...)
Old Apr 7, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Old Apr 7, 2005
2K1Civic17"Gabe's Avatar
tokicos are very stiff. They are awesome though, just avoid all bumps when possible, and work your suspension out some from dodging sh** in the road all the time. It gets better, a little stiffer than when you first put em on, but you will learn to drive more comfortably
Old Apr 7, 2005
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
wow...lol makes it seem so complicated =P
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
shindrome
Exterior
May 5, 2015 02:50 PM
superstanko
Apr 28, 2015 04:38 AM
