coil-over plugs
Old Mar 28, 2005
02CIVYEX's Avatar
02CIVYEX has a little shameless behaviour in the past
coil-over plugs
how often do you have to change them. and i was also wondering if that is the reason why i have a misfire in 2nd and 3rd cylinder randomly
Old Mar 28, 2005
PunkingCivic's Avatar
I need TP for my bunghole
coil-over plugs?, LOL
Have a someone/some place scan the ECU for trouble codes.
Old Mar 28, 2005
02CIVYEX's Avatar
i did at at autozone thats what they said that was the second time i took it the first time and i thought it was cause i didn't have any bolts holding down the plugs but i had replaced them and still the same
Old Mar 28, 2005
robbclark1's Avatar
Retired suspension supermod.
replace your spark plugs. If the doesn't help then get two new oem coil packs for those cylinders.
Old Apr 4, 2005
02CIVYEX's Avatar
i had already replaced them with bosch platinum 4 still doest it. do i have to replace my timing belt because i had bent 13 valves and i think i might of stretched the belt by over reving
SimpleUser
Apr 24, 2021 02:54 AM
mikey1
21
Aug 27, 2015 06:38 AM
fecrni
Aug 8, 2015 06:15 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
MamaBear2015
Jul 3, 2015 11:26 PM
