DYNO RESULTS!! (Link to Dyno Sheet in post number 10)
Old Mar 27, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I went to Rage Performance in Montclair, CA on Friday and had my car dyno tuned. The shop is really clean and well taken care of. They had the spoon sports Honda Fit in there and some 500hp Crx's and alot of other badass ****.
Anyway everything went smoothly except for some problems programming my Profec BC. The BC kept bleeding off too much boost so there is a hump in my dyno sheet. This morning I switched it over to manual mode and I think I fixed it so my car is probably making even more power now but.....................
on their Dynojet I put down 199.47 HP and 196.53 Ft.-Lbs at 8 psi.
I'm trying to resize the dyno image enough to post. If anyone has any suggestions for resizing or if someone could host it I would appreciate it.
I'm running a custom kit with a T3 Super 60, a 3in. DP and exhaust with a HKS Carbon Ti Muffler, and my dumptube is open to atmosphere. For fuel I am using Type S injectors ($35 from clubrsx) and the Emanage with all harnesses.
I'm going to try to get that dyno posted as soon as possible (hopefully before tomorrow).
Old Mar 27, 2005
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
congrates man, that sounds good...post up some pics of that kit so that we can check it out...
Old Mar 27, 2005
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
wow, great numbers. I'm looking at running around 8psi also. Good luck with everything and enjoy the boost.
Old Mar 27, 2005
Drk01Civic's Avatar
Thanks. It's a whole different car now. JW, there are some pics of when I was doing the install in my members ride's photos. I am probably going to get all new photos of the car later this week or next week.
Old Mar 27, 2005
Drk01Civic's Avatar
I told them that I just wanted the car tuned for 8 psi because I had heard that the Type S injectors start to max out around there but the tuner said I had room to boost even higher.
Old Mar 27, 2005
jwcardy's Avatar
i didnt go to the 2nd page last time...the pics look good...do you mind me asking who did your ic piping
Old Mar 27, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Just watch your air fuel. If you keep increasing the fuel and it doesn't change then back off!
Good dyno runs. Any details on the setup?
Old Mar 27, 2005
zachgeyer's Avatar
nice
Old Mar 27, 2005
mxcivic's Avatar
mxcivic is an unknown quantity at this point
can i run 8 psi whit type S injectors an vafc2 ?
Old Mar 27, 2005
Drk01Civic's Avatar
Ok, I compressed the file (a little too much). I'm at work and am kinda busy. But like I said before, there were problems with my boost controller on this run that I have since corrected so there is no longer a drop in power between around 4750 and 5500 rpms.
http://www.7thgencivic.com/memberrid...cat/500/page/1
Old Mar 27, 2005
Drk01Civic's Avatar
Thanks, I bought U bends online, pieced them together how I wanted, had a local muffler shop weld them together, and then had them powdercoated.
Old Mar 27, 2005
Drk01Civic's Avatar
Air/Fuel looked great. I'm going to be running 8 psi for now. Hopefully in the next couple months I'll do a return fuel conversion, get a PnP, and another dyno tune and see if I can increase boost at that point in time.
Old Mar 27, 2005
Drk01Civic's Avatar
I wouldn't. In fact I wish I would have waited for an AEM EMS.
Old Mar 27, 2005
Chris3k2's Avatar
Chris3k2 is an unknown quantity at this point
how much did it cost to get them powder coated?
Old Mar 27, 2005
Drk01Civic's Avatar
I think they charged me $150. I got ripped off. I know a guy who got 4 rims powdercoated a couple days later for $100. They said some bullshit about candy colors being more expensive.
Old Mar 27, 2005
pnoyster2k1cvic's Avatar
Balut Eating Champ
great numbers man... **** I need to dyno my ride too... can you hook a pnoy brotha up? I'm from vegas and factorxengineering suk ***... so let me know what's up...
Old Mar 27, 2005
HyaBoosta's Avatar
what happed to the A/F when it hits that powerdrop?
Old Mar 27, 2005
Drk01Civic's Avatar
It got a little rich and then evened back out. No more power drop now, though. I switched over to the manual mode on the E0-1 instead of using the auto learn feature. I am going to mess with the auto learn feature a little more just to see if I can improve boost response even more.
Old Mar 27, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Nice power, 200 with BC probs. Think about the power when that curve is the way it should be... Next time you dyno it, get some a/f #'s for insurance...
Old Mar 27, 2005
dezod's Avatar
7thgen Power Maker
Your power band looks VERY strange......
Old Mar 27, 2005
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
those are some very nice torque numbers...
Old Mar 27, 2005
jwcardy's Avatar
he explained why it looks that way, but he fixed it
Old Mar 27, 2005
Drk01Civic's Avatar
WERD!
I tried using the auto boost mode again and it seems to be working right now. I really like the Profec E0-1. It's taking a little while to get everything dialed in but I think it will be worth it once it's done. I think next week I'll be purchasing a wideband A/F gauge. I can't wait to take this bitch to the track.
Old Mar 28, 2005
Hey Drk01civic when you set the E0-1 to manual mode at what percentage did you set your gain at. I have the E0-1 and this thing has way to many functions. Also are you running a low and high boost setting or just 8psi. I was thinking of running 5psi for everyday drivind and then change over to 8psi when I get on it. I only have one question. When you set low and high boost does it change to high boost automatically or do you have to do it manually. Thanks.
Old Mar 28, 2005
Drk01Civic's Avatar
You have PM
Old Mar 28, 2005
Well I'm not boosted yet. I have the gauges installed along with the E0-1 but I'm still waiting on the turbo install. I'll be boosted within a week or two. Oh thats why they have that remote switch, to change from low to high boost.
