DIY: Alarm and remote start
From: Ricemond B.C. Canada, British Columbia, Canada
This guy is talking about diode isolating three wires for the doors???...why not just tap into the negative trigger wire going to the dome light???...this would make life alot easier
good point swifty. maybe he does it that way in case someone has turned off their domes. i know, very unlikely.
1028, keyless entry too. he describes how to hook it up to the locks.
-a-
-a-
<< good point swifty. maybe he does it that way in case someone has turned off their domes. i know, very unlikely.
-a- >>
Even if you turn off the dome light the negative trigger still goes to it, it is just interupted by the switch on the dome light itself
depending on your alarm there shold be 3 trigger wires for door trigger . okne shouldbe a instant trigger, the other actual door trigger, you can use the instant trigger and the door trigger and tap it to the 2 door trigger wires ..
if you tab the wire into the dome light, the alarm will be turn on even if your door is open because our car the dome light got the timmer so it turn of about 10 to 15 munite , i just got done hooking the remote starter and alarm on a manual with lcd paging
Civic2002lx
Oct 7, 2015 09:17 AM
MamaBear2015
May 3, 2015 02:17 PM
black2k1vtec
Dec 6, 2001 09:49 PM
loquito
Nov 12, 2001 07:24 PM
