Question on cleaning engine through throttle Body
Old Mar 23, 2005
Storm897's Avatar
Storm897 is an unknown quantity at this point
I have a 2001 Honda Civic and am planning on cleaning the engine through the throttle body this weekend. I was wondering what number on the picture below is the intake hose to the throttle body?
Below is the description from a website I got this pic off:
code:
Illustration No. Description
001 VALVE SET, ROTARY AIR CONTROL
002 BODY ASSY., THROTTLE (GY78A)
004 STAY, THROTTLE WIRE
005 STAY, PURGE CONTROL SOLENOID
006 SEAL, ROTARY AIR CONTROL RING
007 PORT, SERVICE
008 VALVE, PURGE CONTROL SOLENOID
010 TUBE A, PURGE
011 TUBE B, PURGE
012 TUBE C, PURGE
013 SCREW-WASHER (5X10)
014 SCREW-WASHER (5X20)
015 NUT, FLANGE (6MM)
016 CLIP, TUBE (B12)
017 BOLT, FLANGE (6X14)
018 BOLT, FLANGE (6X45)
Thanks,
Oren
Old Mar 23, 2005
blouisgod's Avatar
Life Begins > 6800rpms
what intake hose are you talking about?
Old Mar 23, 2005
Storm897's Avatar
Theres an intake hose leading to the throttle body. You disconnect it and feed either seafoam, or some have tried water through it.
Old Mar 23, 2005
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
Try seafoam, it works better
Old Mar 23, 2005
MarkM01's Avatar
MarkM01 is an unknown quantity at this point
If you really want to do this, another option would be to just spray the solution with something like an empty Windex bottle, striaght into the t/b. Just do it slowly.
Old Mar 23, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
um, what are you wanting to clean? I know you said the "engine" but what exactly are you trying to clean? if you are wanting to clean carbon out of the cylinders, just slowly pour some ATF into the trottle body and keep the engine rev'ed up so it doesn't stall. it will puff a lot of white smoke, but that's ok. the atf will leave the cylinders spotless inside. if you are just trying to clean the valves, intake, and tb... just spray carb. cleaner in there while the engine is running and keep it rev'ed up.
Old Nov 18, 2009
fkov's Avatar
fkov is an unknown quantity at this point
Question throttle Body diagram
What is the description of the illustration number 9 please? Thank you.
Old Nov 18, 2009
Re: Question on cleaning engine through throttle Body
looks like some sort of valve for the evap emissions system.
davidpaustin
Apr 29, 2015 02:23 PM
green01civic
Apr 29, 2015 01:36 PM
mievil
Apr 28, 2015 11:02 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
