[HELLLLPP] No Audio Power@!!
From when the winter started, my deck stopped working when it';s cold
and after inside of my car worms up, the power comes up and started the deck.
but now, for few months, I had no 12v power at all to the deck (no constant nor acc)
so I desided to wire my deck to cig. light but when ever I turn the volume up, it dies. Also it restes everytime I take my keys off.
it's not my decks problem since I tried with other decks
I checked the fuses, and they are alrite
something might have burnt down?
Where should I wire my deck to now?
is this common problems?
what about your fuses? when you hooked it up to the cigarette lighter, and turn up the volume, it sounds like you're over-powering the fuse. the stereo will definitely use more power than the cigarette lighter.
It's grounded to stock audio Wireharness
everything is connected to stock wire harness except two power wires
(1 for constant and 1 for Acc.)
Yeah, I need a better sources to wire em up when cig lighter 12V
sch2cm
Jul 21, 2015 09:58 PM
breanna_17
Jul 21, 2015 04:01 PM
