Custom IM
Old Mar 15, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Question Custom IM
I was wondering, since i've there have been a lot of people custim fittng them either from 6th gen civic and one fomr a d16y8, what does the custom work involve???
Is it that the in doesn't mount directly, meaning that you have to modify the hole that ataches it to the head, or is it just extending the wire for the TB??
thanks..
Old Mar 17, 2005
turboengnr's Avatar
DONT PANIC
the stock manifold is a plastic plenum and runners which attaches to an aluminum injector plate which bolts to the head. Basically you can take any aluminum manifold, cut the flange off behind the injectors, and weld it to our injector plate.
When i pull my motor to put the built one in, i will be making a manifold to fit my car. Im thinking of a GSR or Type R manifold because #1 they flow quite well stock (and even better after i port them) and #2 they look badass.
Hell, if you wanted to, you could probably put a damn Saturn manifold or jetta manifold on your car if you wanted. As long as its aluminum and the ports come close to lining up, i say go for it.
Old Mar 18, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
you don't want to go welding ****....bad idea. I'm going to try it this summer and I've already been comparing them and really putting a lot of thought into it. I have an engine harness for the y8 also, so I'm just going to splice the clips and use the y8 sensors...much easier than creating a remote IACV and making the map hole bigger and screwing around with the TPS. There are also a lot of vac line fittings on the y8 which is nice for hooking up turbo vac lines. Looks much better than T fittings. When I do it, I'm going to do a step by step DIY with pictures and everything. I have 3 y8 IM's so I can **** up two and still be ok :P . If you aren't ready to go to a return line yet, you can still do the swap. you just plug/clamp the return line from the fuel rail and it works just like the stock fuel rail. But you will need at least a SAFC to adjust the fuel cause I know the d16 and d17 injectors are diff. and will need to be adjusted. here is a link to a thread where a guy did it. This guy did an awesome job too. I'll bet that y8 helped the turbo a lot compared to the plastic piece of crap we have now. He just didn't give a lot of info about doing it is all. so I'm going to pick up where he left off
http://www.d-series.org/forums/showthread.php?t=14453
Old Mar 18, 2005
PunkingCivic's Avatar
I need TP for my bunghole
here are a few images I have acquired for custom intake manifolde on a d17
Old Mar 18, 2005
bradmanuwf's Avatar
that venom is sweet, but I don't think he wants to spend that much money on just an intake....I wouldn't unless I was rich and could go all out with my engine and get it putting down like 400whp. but that's just me.....
Old Mar 18, 2005
Blue_Honda_Civ's Avatar
I drive a jeep to compensate for my tiny pee pee
Blue_Honda_Civ will become famous soon enoughBlue_Honda_Civ will become famous soon enough
how much is something like the venim
Old Mar 18, 2005
bradmanuwf's Avatar
probably about $400-500 not sure. never looked for one. hell, maybe more since it looks like a custom job, and those are always way more.
Old Mar 18, 2005
xX03EXx's Avatar
Sweetest Dude on 7th Gen
That venom one looks fly. I don't know if the investment is worht the gains though.
Old Mar 18, 2005
bradmanuwf's Avatar
that's what I was thinking. a y8 will run you about 50 tops on ebay. that venom is..... who knows.
Old Mar 18, 2005
check out the new venom I.M.
The "Eco-Tec Intake Manifold"
Made of T6061 Aluminum
Bolt on Fit no modifications required
Lightweight design
Comes in Red, Blue, Polished, and machine finish
http://www.venom-performance.com/nf/.../imanimage.htm
Intake manifolds are CNC machined billet aluminum head flange and intake runner surface CNC machined runners to reduce turbulence thus increasing the speed and volumetric efficiency of intake manifold. The manifold excepts up to 66 mm throttle body. Can be used on naturally aspirated or under forced induction. The Polished manifolds make a great addition to any show car.
Old Mar 19, 2005
Tomola's Avatar
Tomola is an unknown quantity at this point
whats the price of this Venom IM, expected gains?
Old Mar 19, 2005
C2i0v0i1C's Avatar
SuperMODrizd
no application listed for our cars
Old Mar 19, 2005
Tomola's Avatar
dahm that sux
Mad Dog Tannen
Oct 19, 2016 08:12 PM
rallyeredem0
Nov 2, 2015 10:56 PM
carid
Sep 28, 2015 10:13 AM
General DIY
Sep 25, 2015 08:02 PM
Jrosa
Sep 14, 2015 08:24 PM
