tech day gauging intrest
Old Mar 13, 2005
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Exclamation tech day gauging intrest
Well I need to know how many people would come to a tech day if I had it on the 19th. I think it would be better for everybody on the 26th. But some can not make it. I might just have 2 but I nned to see. I don't want to plan these and nobody shows up. Let me know.
Old Mar 13, 2005
wonderz's Avatar
wonderz is on a distinguished road
just wondering, if to modify the stock strut for koni, do you need the koni to check fitment? 'cause I have an extra pair of front strut that needs to mod, but don't have the koni yet. planning to get that new koni suspension kit.
basically i want it to be done in two separate days, one day is to mod it, then i can take it home and spray paint it and let it dry. then the other day for install.
either way, i'll come for the tech day. but just wondering about the koni installs too.
Old Mar 13, 2005
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
i am down for both tech days. count me in with a couple of good things to do. also crew u got air tools?
Old Mar 13, 2005
CrewChief's Avatar
all you have to do for the konis in the front is to drill a small hole in the bottom of the front strut to let out the oil and pressure and use a pipe cutter to cut off the top of the strut. about 1/2 an inch from the top
sorry no air tools. might be able to use my niehbors though why?
Old Mar 13, 2005
xam's Avatar
xam
i wanna put my front brake rotors on but i need a air wrech to get the phillips screws out
Old Mar 13, 2005
CrewChief's Avatar
you just need one of those screw drivers that move when you hit it with a hammer. thats all. they are like 10 bucks
Old Mar 13, 2005
wonderz's Avatar
i don't have the pipe cutter thing and too scare to drill holes into a pressurized tube, so can you help?
Old Mar 13, 2005
Akutenshi's Avatar
The Rizing Sun
i think i can make it both days. if not, 26th fo shO.
Old Mar 14, 2005
ZapThyCat's Avatar
ZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to behold
Either or both. I'd like to show up, hang a while.
Old Mar 14, 2005
gh0st's Avatar
TAQUITOS!!!!
rotor and pad install?
Old Mar 14, 2005
wonderz's Avatar
i can do these. and i think crewchief would have all the tools needed.
just bring it over to tech day and i am sure someone can help out on it.
btw, i still need ppl to help moding some stock strut housing for koni.
Old Mar 17, 2005
jackal903's Avatar
jackal903 is an unknown quantity at this point
so....is the tech day happening on this comming Sat? i want to change my front sway bar to RSX sway bar....and change the rear drum brakes shoes...
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
justheman
Dec 30, 2001 06:50 PM
