tech day gauging intrest
Well I need to know how many people would come to a tech day if I had it on the 19th. I think it would be better for everybody on the 26th. But some can not make it. I might just have 2 but I nned to see. I don't want to plan these and nobody shows up. Let me know.
just wondering, if to modify the stock strut for koni, do you need the koni to check fitment? 'cause I have an extra pair of front strut that needs to mod, but don't have the koni yet. planning to get that new koni suspension kit.
basically i want it to be done in two separate days, one day is to mod it, then i can take it home and spray paint it and let it dry. then the other day for install.
either way, i'll come for the tech day. but just wondering about the koni installs too.
all you have to do for the konis in the front is to drill a small hole in the bottom of the front strut to let out the oil and pressure and use a pipe cutter to cut off the top of the strut. about 1/2 an inch from the top
sorry no air tools. might be able to use my niehbors though why?
you just need one of those screw drivers that move when you hit it with a hammer. thats all. they are like 10 bucks
Originally Posted by gh0st
rotor and pad install?
just bring it over to tech day and i am sure someone can help out on it.
btw, i still need ppl to help moding some stock strut housing for koni.
so....is the tech day happening on this comming Sat? i want to change my front sway bar to RSX sway bar....and change the rear drum brakes shoes...
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
