Vid – my vic getting dyno tuned! Screaming!
Old Mar 6, 2005
Tomola's Avatar
Tomola is an unknown quantity at this point
Talking Vid – my vic getting dyno tuned! Screaming!
** Link has been removed - due to high bandwidth on server **
I installed the Apexi S-AFC II thanks for the DIY.
Had this place tune my civic, car is so nice and smooth to drive now
Picks up the gears so much faster! Was running way to rich between 4-4,800K. The AFC goes up to -15% around that rev range and sounds so nice
Old Mar 6, 2005
h0nd4_r1c3r_X's Avatar
h0nd4_r1c3r_X has a little shameless behaviour in the past
why the heck is your wheel on that side?
Old Mar 6, 2005
streetglower's Avatar
probably lives in another country
Old Mar 6, 2005
jfan's Avatar
And the results of the dyno run were...
Old Mar 6, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
what where your before and after hp/trq. numbers?
Old Mar 6, 2005
Logan3024's Avatar
so what did your numbers end up being? Do you have a k series or d series?
Old Mar 6, 2005
diskreet's Avatar
If its right hand drive (didnt watch yet) then it should be of the K20 family.
Old Mar 6, 2005
ELaudio's Avatar
ELaudio is an unknown quantity at this point
The video's server is in Australia... Could explain it.
Old Mar 6, 2005
Tomola's Avatar
Yeah i'm in Aus...
The HP hold on a sec i'll run down to my car and photocopy the dyno grapth..
Old Mar 6, 2005
ncirom2003's Avatar
sounds pretty good. wether its k or d series i personally think b18's sound best on dynos
Old Mar 6, 2005
Tomola's Avatar
Yeah B series do sound sweeter! Double Over's make it louder. It's a D17 non-vtec.
Following Mods:
-Axel Back custom made stainless steel 2 1/2" exhaust with high flow cat.
-Custom made Ram-pod.
-S-AFC II
Everything else is stock.
- Dyno stock 65.4 Kw at the wheels
-Above mentioned bolt-ons and tuned makes 77.8 Kw at the wheels
That's a total increse of 12.4 Kw at the wheels. Forget what the conversion to HP is, someone work that out....
However I will soon also get some headers made up and then; I'm still to decide weather to get Turbo setup or stroke it and build it up internally. I love NA cars... I prefer to drive them than Turbo's.
Yes sure at the end of the day the turbo will be faster! However with the same $$ investment - You could make this D17 pretty ripped and fun to drive... any suggestions.
Old Mar 7, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
FYI, 77.8kW is about 104HP
Old Mar 7, 2005
bobsagator's Avatar
Nice gains on the numbers tho. What gear was your car dyno'd in? It looks like 4th from the video. Just asking since your first dyno says 3rd...
Old Mar 7, 2005
Tomola's Avatar
Yeah it was 4th gear in the video thats why it's so slow!!
I like it when they Dyno in 3rd pulls so much faster
Old Mar 7, 2005
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
auto or manual?
Old Mar 9, 2005
Tomola's Avatar
manual
UltraHDGames
Jun 8, 2016 05:16 PM
shadowfist
Oct 18, 2015 02:38 PM
beanhead
Sep 24, 2015 12:04 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
