? about heat sheilds for air intake
Old Jan 3, 2002
AnotherDopeStyle's Avatar
AnotherDopeStyle is an unknown quantity at this point
do heat sheilds really work or do they restrict the airflow?
Old Jan 3, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
Some seem like thay would restrict some air flow into the filter, but some are good.
I don't know who makes just the heat shield though. If you find out, let us know.
Old Jan 3, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Raceactive sells air filters with heat shields
Old Jan 3, 2002
01blackCVC's Avatar
01blackCVC is an unknown quantity at this point
I think injen makes heat shields. They look really nice too. Its polished stainless and just wraps around the filter of your aftermarket intake. I think it comes in sizes depending on the application.
Old Jan 3, 2002
CapYoda's Avatar
Escaped Convict
I dont think it works. not really anyway.
well, at least, not InJen's one...
the thing u want to block out is the hot engine bay air... not the hot engine... which is the cause...
since the heatshield doesn't enclose the air filter completely and keep it seperate from the engine bay air, you're still sucking in those hot engine bay.
nor do I think the ractive filter with heatshield works... I mean you're still sucking in hot engine bay air with that thing too.
well, what I suggest falls in the line of short ram intake systems anyway... course u wouldn't really be using that thing with a CAI... I guess u can use it as a splashguard?
I dont think restricting air flow is a problem... the issue is, does it do anything at all? IMO, none. or, barely anything.
Old Jan 28, 2002
alienmonkey's Avatar
alienmonkey is an unknown quantity at this point
I'm curious if the heat shield works too. I was gonna get an injen ca and a bypass valve and came accross the heat shield.
Old Jan 28, 2002
blouisgod's Avatar
Life Begins > 6800rpms
if it does work, it prob will yield not a noticible gain in hp. it is prob just for looks i think
Old Jan 28, 2002
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
i just think it's for show, at least the injen one
i've seen some custom made one where it blocks off
a whole corner of the engine bay area. now i believe those work
but as far as these new one i just think their another way to make money
and if your putting it on a CAI what's the point?
isn't the CAI relocating the filter away from the hot engine bay?
so now, if anything, wouldn't it be blocking the cold air
mistermenphis22
Jul 13, 2015 04:43 PM
7thgensurvivor
Jul 5, 2015 12:17 PM
ORskier
May 7, 2015 04:54 PM
carid
Apr 30, 2015 07:00 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
