DIY Ground kit facts
Old Feb 28, 2005
03civicdx's Avatar
03civicdx is an unknown quantity at this point
Hello, id like to clear up something on the diy for ground cable install. The way he has it done is fine but it is excessive, i had the nice chance to dyno test some of my theories. all you need is one from the battery to the trans case, and one from the battery to the block and to the frame above the radiator ill post pics as soon as i can get my digital camera back, but i saw a gain of just under 1 hp with that and adding more did nothing good diy but a bit excessive is all enjoy.
Old Mar 1, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
good post
Old Mar 1, 2005
yup that's what I did. Use factory ground points, 4 gauge wire, and tie it all back to the battery.
Old Mar 2, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
Please refresh what the additional grounding does/is for.
Old Mar 2, 2005
It stabilizes the flow of voltage for all the electrical accessories on the car. You won't notice much with just the wire upgrades tho. Get the HVS ( hyper voltage system) and you'll feel a difference.
Old Mar 3, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
can you post dyno graphs? How much you putting down?
Old Mar 3, 2005
I didn't dyno it separately, but it's known to give a few hp at least. Ground wires are good for maybe 1hp on our cars. I've seen a wrx with new wires gain 5.5whp from a magazine dyno. Doesn't seem to help us much. Here's a company dyno, so it might not be entirely accurate. HVS = hyper voltage system, HGS = hyper ground system (wires only).
integra type-r
Old Mar 3, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
can you make those bigger?
Old Mar 3, 2005
no that's how big they are
Old Mar 3, 2005
oh...well what does the first one show
Old Mar 3, 2005
bobsagator's Avatar
Is there a reason there is a power increase if this is for electrical components? Does it eliminate some parasitic draw from the engine? Is this better for someone with additional electrical components than someone with stock ICE? Because if Gearbox recommends it, it's on my list of things to get!
Old Mar 3, 2005
Ya the hvs combined with ground wires does make a difference. I took it off cause I didn't think so, but it went right back on after I felt the loss of power. It's not much, but it's something. All I have is one small amp for the speakers, so it definately helps even a stock car. Everything on your car benefits from better grounds because it's all electronic.
Old Mar 3, 2005
03civicdx's Avatar
i cant post my dyno till i get a scanner... well get it back lol but i put down 105 i think with 105 ft/lbs of torque
Old Mar 3, 2005
kornsined's Avatar
post some pics of your grounding points too.
Old Mar 5, 2005
Redline04's Avatar
yes please do.
I see you don't have any mods listed so assuming your stock. 105 is pretty damn good.
Old Mar 5, 2005
jttegx's Avatar
OMNES AD UNUM
when u say the block, do you mean valve cover?
so would it still be neg > radiator support > valve cover (block) still?
please post pics
Old Mar 5, 2005
Find all the actual stock grounding points and run a separate wire from each one to the negative terminal of the battery.
Old Mar 6, 2005
03civicdx's Avatar
i have a SRI and i cut the resonaters out thats it on a single cam non vtec so im pretty happy allthough the car is getting a cam this week aswell as the rest of the exhaust ill post pics and dyno as soon as i get the stuff i need to do so
Old Mar 9, 2005
Redviking's Avatar
Redviking is on a distinguished road
... ill post pics and dyno as soon as i get the stuff i need to do so
Don't forget us!
Old Mar 10, 2005
03civicdx's Avatar
im sorry im still working on it and its been snowing this weekend for sure i will get pictures for you all thanks for being patient
Old Mar 10, 2005
Redviking's Avatar
Ok no problemo!
I just want to ensure I have the same location as you... I am not sure of what you mean by "block". Is it the thermostat housing (stock location, B on the picture) or the actual valve cover (location A)?
Presently I have this set-up in 4g wire:
1) I replace the stock wire battery-chassis-tranny by 2 wires: #1 Battery to Tranny (stock location) ans #2 Battery to Chassis (stock location; passenger strut tower under the fuse box)
2) I replace the stock wire between thermostat housing and radiator support
3) Battery to Thermostat housing (is it the "block")???
Thanks man!
Ray Darvi
Aug 12, 2015 11:55 AM
j-chest
Jul 31, 2015 01:18 PM
cyc
Jul 22, 2015 01:14 PM
chrisjackson321
Jul 12, 2015 03:00 PM
Jul 12, 2015 11:54 AM
