radiator fan broken...car overheating
Old Feb 25, 2005
specks's Avatar
specks is an unknown quantity at this point
found out the my radiator fan is not coming on when i turn on the ac and also i never hear it come on anymore at all. so my car has been overheating and i was wondering what i should do to fix this overheating problem. how do i check to see if its the fans fuse, the thermostat, or the fan itself. and can someone tell me the process of "jumping" the fan to start. I heard that i can just jump the fan to a battery source to check to see if it still works.
Old Feb 25, 2005
Logan3024's Avatar
Crank on the A/C and hold your rev's at 3000 once car is fully warmed up. If the fans dont come on within 2-3 minutes, Very good chance your fan/fuse is not working properly.
Old Feb 25, 2005
streetglower's Avatar
First things first. Check the fuse. If that is ok, then check the fan motor.
Old Feb 25, 2005
djmota's Avatar
and if thats ok replace the fan switch.
Old Feb 25, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
I doubt it's the fan(S) since there are 2 of them. 2 motors don't die at the same time. Check the fuse, and then try the temp sending unit that tells the ecu when to tun on the fans. There are 2 relays, the regular fan relay, and the AC fan relay that turns BOTH fans on.
If you can't find the problem, I can look in the service manual for you.
Old Jan 1, 2010
FrankDel's Avatar
FrankDel is an unknown quantity at this point
Re: radiator fan broken...car overheating
I have a 2005 civic I had the timing belt and water pump replaced last month, after driving it about 1000 miles, I was on the highway I turned on the heater and the temp started to get hot almost to the max. I turned off the heater and the temp went back down. About 2 weeks later I was ideling parked and the same thing happened, once I turned off the A/C the temp went back to normal. I always have the a/c on but it only happened twice. I drive alot about 160 miles a day. I have checked the fans and they both turn on when I turn the A/C on, is thier a relay that could be going bad and failing intermitently? The car has 205,000 miles. What could be causing this?
liagreenhalgh92
Jul 21, 2015 01:31 PM
Kyles24
Jul 16, 2015 10:14 PM
EliseKStewart
Jul 15, 2015 11:11 AM
Kyles24
Jul 12, 2015 09:15 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
