How much Boost???
Old Feb 24, 2005
ShadyImprtracer's Avatar
ShadyImprtracer is an unknown quantity at this point
How much Boost???
I just recieved my HP performance kit and it included the following except the injectors and emanage and im wondering how much can i safely boost while daily driving with this kit?
Garrett T3 AirResearch .50 compressor .48 exhaust turbine
Jet Hot coated charge pipes
Jet Hot coated full tubular manifold
FMIC
Bosch blow off valve
RSX Type S injectors
NGK Iridium plugs
External .38mm Tial Wastegate
Greddy Emanage w/ Ignition harness
Oil Lines
Hallman manual boost controller
Old Feb 24, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
6-8psi will be acceptable.
Old Feb 24, 2005
TheSmuggler's Avatar
None, lol, trust me
Old Feb 24, 2005
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
if u dont have naything to control the injectors and ur running on the stock set up, dont ron on ANY psi, because you have nothing for ur engine to read the extra boost to throw the extra fuel in the engine, there for ur gonna run lean... LEAN IS BAD... itll melt ur piston like butter... dunt drive.. be safe and paitent
Old Feb 24, 2005
civic01vtec's Avatar
you get e-manage tuned.....there is no reason why you can't run 8-9 psi safely.
Old Feb 24, 2005
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
he's got emanage, gosh what are you thinking
Old Feb 24, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
If you don't have your Emanage or injectors yet, don't go into boost. The End.
Old Feb 25, 2005
aellerman's Avatar
aellerman is an unknown quantity at this point
you got alotta the same stuff i've got for my turbo setup... like exactly the same...
emanage, injectors,boost controller,wastegate, all the same... i think im gonna tune my setup for 7psi until i get the return line conversion from SLP then i'll go up to 8ish
Old Feb 25, 2005
ruckus1's Avatar
ruckus1 is an unknown quantity at this point
ok im stupid, what is emanage and what in the world is a wastegate?
Old Feb 25, 2005
omfg read up top guys it says he DOSENT have the emanage or injectors
Old Feb 25, 2005
he says not yet.......i am assuming that he will wait to install the kit when he gets them...........at least i hope
Old Feb 25, 2005
^^Don't assume, it makes an *** out of u and me
Old Feb 25, 2005
Oh yeah and where does it say yet, it says he got his kit but he dosen't have emanage or injectors lol, you need to read more closely
Old Feb 25, 2005
oh well........it isn't my car
Old Feb 25, 2005
^^haha own3d lol
Old Feb 25, 2005
^^haha own3d lol
Old Feb 25, 2005
2K1Civic17"Gabe's Avatar
yeah, dont boost yet dude, get emanage and some injectors or something to put fuel in there. Your go boom fast, even off 1 or 2 psi you can blow your motor.
Old Feb 25, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I agree about not boosting without extra fuel. However if you recieved the alchy injection with the kit (standard with the kit) they have designed it to run on aprox 5.5 psi. I know many people here will argue with me on this but it has dynoed to be more than safe to rely on the alchohol/water combo at 5.5psi. You will use roughly 2 quarts per tank of fuel. You still need to tune the injection with the supplied control module. If you bought the kit used and didnt recieve alchy injection then upgrade to the rsx injectors and emanage. Its more beneficial and tunable then the alchy. We all cant stress enough how sensitive proper tuning is. In as little as 5 minutes you could destroy a whole motor.
Old Feb 25, 2005
My problem with using alchy/water as a primary fuel system is that it creates alot of heat. Yeah, the water will cool down the combustion chambers, but alcohol still creates alot of heat. Also, there is no guarantee that the alcohol will reach each combustion chamber. You can be running fine in the #3 chamber, but detonating in #1.
Just my $.02
Old Feb 25, 2005
i just recieved my injectors today and im just saving for my emanage and im wondering how much psi WITH those i can boost?
Old Feb 25, 2005
Old Feb 26, 2005
GREAT! Now...does anyone have an Emanage with an ignition harness up for sale?
Old Feb 26, 2005
so if i go take my car to get tuned after i install my whole kit + my injectors + emanage will they tell me how much i should boost my car at?
Old Feb 26, 2005
**they as in the tuners
Old Feb 26, 2005
depends on the shop..........there are waaaaaaay too many shops out there that are unfamiliar with the D17.
Old Feb 26, 2005
'That's a bummer man' - The Dude....would anyone know of a good shop for tuning in Southern Cali???
Old Feb 26, 2005
Well, your in the gold mine for tuning lmao
Old Feb 26, 2005
Drk01Civic's Avatar
I am going to take my car to Rage Performance in Montclair.
(909) 608-7123 www.rageimports.com
Old Feb 26, 2005
Dude thats like 10 min from me hahah good deal
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
