Nitrous noob question....should I disconnect my nitrous bottle after every use???
Old Feb 22, 2005
VegasJones's Avatar
VegasJones is an unknown quantity at this point
I just installed my nitrous this past weekend and I've just been messing around with it around town to get a feel for it....but when I'm done driving I don't know if I should disconnect the hose and waste all that nitrous that's pressurized in the hose...or if it's okay to just leave it hooked up with the pressure there???
Also, how much nitrous do you think I waste by disconnecting the hose from the bottle everytime???
Old Feb 22, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
id say keep it connected but just close the valve over the bottle. you should be fine
Old Feb 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
buy a purge valve kit and blow off the pressure after your done using it. This way no risk of the NAAAWWWWWS leaking in to the intake manifold and blowing the WELDS !
Old Feb 22, 2005
VegasJones's Avatar
ya think the solenoid would really let it thru??
Old Feb 22, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
NEWB?????
how the hell is naws going to leak into the intake manifold. as long as you keep the bottle off its going to be fine. I actually leave mine on for the night just incase anyone tries to steal it. Besides lets say you have some nitrous left inside the lines. Its way too little to do anything. You wont waste much when you take off the lines but I suggest leaving the lines on. If you keep taking on and off the teflon washer inside the -4 an screw will get loose and you will need to buy another one if you keep disconnnecting/connecting it.
So just leave the bottle hooked but dont worry about it blwing cuz that will never happen. Remember to turn it off too.. You dont need a purge kit to purge the nitrous. Just press gas on hard with the wot switch on and the bottle valve off. It works just as good.
This is what I do routinely when unscrewing the bottle for fill-ups.
Old Feb 22, 2005
Havok2k1's Avatar
Wicked Pissah Admin
If you had any lengthy experience with the gas you would know that solenoids deteriorate (sp?) over time and need to be rebuilt over the years....
Civic_Redline = NEWB
Buahahhahahahahah
Old Feb 22, 2005
im stock now! T.T
they do not need to be rebuilt. you can change filter or clean it.
Old Feb 23, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Cleaning a filter has absolutely nothing to do with the operation of the solenoid. All it does is make sure debris doesn't inhibit solenoid / spray nozzle operation....
Old Feb 23, 2005
im stock now! T.T
well from the way your saying it, it seems as if a solenoid will go bad instantly. Think what you want but they didnt make nitrous work that way.
jackoncruzpr
Sep 29, 2015 07:59 PM
ttamrekab
Sep 28, 2015 01:22 AM
Bruce2
Sep 27, 2015 08:45 PM
Sep 27, 2015 11:33 AM
Bruce2
Sep 21, 2015 08:01 PM
