slight drift...
Old Dec 31, 2001
2k1USMCivic's Avatar
2k1USMCivic is an unknown quantity at this point
slight drift...
anyone starting to notice a slight drift to any side when you try to drive on a straight road without your hand on the wheel? bad thing is, i just had my tire pressure checked & rotated, so im pretty sure that it isnt because of my tire pressure... what could be the problem?
Old Dec 31, 2001
Ed's Avatar
Ed
HOw long does it take to go in which direction?? I know cars are suppose to start drifting to the right after a while, but if it does it really quickly and all the tirs are of correct pressure, it's probably an alignment problem, take it to get re-aligned.
-Ed
Old Dec 31, 2001
insan's Avatar
insan is an unknown quantity at this point
i have that same problem. its not too bad but i took it to the dealer and they said the same thing ED said,,Aliment.......i hope that all it is
Old Dec 31, 2001
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
my car might pull a tiny *** bit, but then again, I need to get my frame straightened.
Old Dec 31, 2001
emmagatorone's Avatar
emmagatorone is an unknown quantity at this point
WHAT ARE YOU DOING WITH YOUR HANDS OFF THE WHEEL?!!!
Old Dec 31, 2001
BAK's Avatar
BAK
BAK is an unknown quantity at this point
Either alignment or it could be that your wheels need to be balanced, if it started after you rotated the tires.
Old Dec 31, 2001
CosmicPulse's Avatar
CosmicPulse is an unknown quantity at this point
<< WHAT ARE YOU DOING WITH YOUR HANDS OFF THE WHEEL?!!! >>
lol [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Jan 1, 2002
Pongster's Avatar
Pongster is an unknown quantity at this point
I have the same experience. Brought it back to the dealer and they said the alignment is fine. They did tell me that it's supposed to drift to the right coz the road is slanting in that direction. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 1, 2002
NightKids2's Avatar
NightKids2 is an unknown quantity at this point
If the car starts to drift drastically when u let go of the wheel, check your alignment. If it's a slight drift, and drifts both left and right at certain times, nothing is wrong.
Sometimes roads are slanted to allow proper drainage when it rains, that way the roads don't get messed up. The best way to check if your car needs to be aligned is to let go of the steering wheel and press on the brakes (make sure your in a safe situation so u dont slam into anyone). If the car starts pullin drastically, you got a problem.
Dont worry, my car drifts slightly all the time, but in my old camry, I could make a full lane change as if i really was turnin the wheel cuz the alignment was sooo messed up.
Old Jan 1, 2002
jmythngdmb's Avatar
jmythngdmb is an unknown quantity at this point
I have slight drift to the right @ 70mph and up, not bad though, think its supposed to do that. At least if you fall asleep, you prolly won't go into on-coming traffic right?[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
JetsterDajet
52
May 8, 2016 12:11 AM
skeener51
Oct 1, 2015 05:56 PM
Wariogamer
Sep 29, 2015 09:49 AM
Bruce2
Sep 27, 2015 08:45 PM
Civic720
Sep 10, 2015 10:06 AM
