Just installed Tokico HP's, Neuspeed Sports and Ingalls Camber kits
Old Feb 21, 2005
daviddittmer's Avatar
daviddittmer is an unknown quantity at this point
I like the drop, but the rear gaps are uneven. In the rear, the driver's side is lower than the passenger side. It's not off by a huge amount, but you can easily notice it at a glance; there is no gap on the driver's side, and about a one finger gap on the passenger side (the difference is around 0.5 inch or 0.75 inch). Considering that I only did a 1.5 inch drop in the rear, I would say that this difference is significant. Any suggestions as to what I should do about it? I don't know if the cause of the difference is the struts, the springs, or some kind of error in the install. I had it all installed at Martell Racing in Manchester, NH.
Another piece of info: The Tokico HP's themselves must cause a drop, because the total drop I got from all these parts is no less than two inches. The Neuspeeds are 1.75 front, 1.5 rear. I'm not complaining; it looks great. However, Tokico says that you should not do more than a 1.75 inch drop with HP's. So, do I have a problem because the total difference from stock to my current drop is 2+ inches?
Old Feb 21, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
ya you might have a problem because the HP's are designed to only handle a max of 1.7
And as far as the gaps, give it time to settle in.
injen
Old Feb 21, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Well I don't know if Tokico rears are the same way, but Konis have adjustable rear perches to account for the variations in location of the lower spring seat that honda threw in by model year. If Tokicos have that and they're set to 2 different heights, that'll explain the difference in height.
Also make sure the rear springs are indexed properly and the coil is on the bottom perch with the end of the winding against the stopper. The lower perch is NOT flat, make sure the spring follows the perch all the way around.
Old Feb 21, 2005
chrisleecool's Avatar
I have the same (problem?)
except i have H&R springs.
it has been 2 weeks since i installed them, it still seems like driver side (front/rear) is a little (not much..like about a finger gap) lower than the passenger side.
I guess they're still settling...i dunno
Old Feb 21, 2005
flotsamm's Avatar
Leaning to the left is normal for our cars.. here's a TSB that explains why:
http://www.7thgencivic.com/forums/lo...on=jump&id=110
Old Feb 22, 2005
Man I have to say I'm a little uneasy about the fact that the drop is so low that there is no gap in the rear. Can anyone explain how a Neuspeed Sport drop on a 2005 Civic would leave my car this low? Maybe they gave me Race springs by accident (the box definitely said "sport" though...). I can post pictures, but it's pretty simple. The top of the tire is level with the wheel well. No gap, no tuck, just level. The ride is good, but I hope my HP's don't get blown out fast because the drop is too much.
Old Feb 22, 2005
QBoi's Avatar
What color are the springs? I think sports are green and race is red.
Old Feb 22, 2005
2K1Civic17"Gabe's Avatar
I have a 1.75" drop, and my left side is just tucking, my passenger side is not. It is normal. My car is over 2" lower than stock and Im on tokicos as well. The springs are a 1.75" drop, which makes the warranty on the Tokicos valid.
Old Feb 22, 2005
I thought SPORTS = RED RACE = YELLOW
Old Feb 22, 2005
QBoi's Avatar
Probably, I've never seen them before. I was just throwing out colors
Old Feb 22, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Neuspeed Sports are Green, and the Race are Yellow
Check again in a couple of days.. it might even out a bit more..
Old Feb 22, 2005
They are red... so, race or sport?
Old Feb 22, 2005
flotsamm's Avatar
Neuspeed Sports are red..
Old Feb 22, 2005
shmik1's Avatar
the 2" estimation is inaccurate.. tokico is saying lowering springs cant be over 1.7.. they wouldnt account for if their hardware makes the car slightly lower.. i never saw anything that said tokicos lower more than the spring does
i have no idea about 1.75.. but 1.75 vs 1.7 doesnt sound that bad.. its over but its only 5/100 of an inch
Old Feb 22, 2005
Huh? I have no gap, man. By the way, I have 15" rims... That has to be at least a 2" drop, wouldn't you agree?
Old Feb 22, 2005
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
depends on how big your tires are...
Old Feb 23, 2005
P185/65R15
Old Feb 23, 2005
Tokicos say 1.75" drop, which is exactly what my springs are at as well. The warrantyy is fine, if y our too low and they blow, you have a lifetime warranty. My car settled a little over 2", probably a little lower than yours, not by much. Dont worry about it. Your fine. Just enjoy, I have had these on for like 7 months probably, and they ride awesome. Some cracking with the Goldlines, but still rides great.
Old Feb 23, 2005
Cracking noises that is, not cracked springs. The normal noise with springs.
Old Feb 24, 2005
flipbagz's Avatar
Go Pistons!
flipbagz is an unknown quantity at this point
would tokico void warranty if you change it from 14mm to 16mm??
Makeice3498
Jul 2, 2015 11:13 AM
andylao
Nov 9, 2001 07:36 PM
JeffSpeed21
Nov 4, 2001 10:32 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
SneakerPimp
Nov 3, 2001 10:57 AM
