Progressive Dynamics PD9160 Power Converter FOR CAR SHOWS !!!
Old Feb 20, 2005
o2civic's Avatar
o2civic is an unknown quantity at this point
AC-DC Converter
Retails for 259.00
Asking: 150.00
Description
Select the Switcher/Converter that is the most reliable in the industry. Progressive Dynamics 60 amp switcher/converter delivers all the best features for the same value pricing as other 55 amp switcher/converters. Delivers quiet, filtered DC power to meet today's higher DC option needs. Features include reverse battery protection, intelligent cooling fan, built-in total charge management system connection, as well as two positive and negative connection terminals. Allows for connection of optional Charge Wizard to constantly monitor and maintain your RV battery.
Tech Notes
  • Input: 105-130V AC, 50/60H, 1000 watts.
  • Output: 13.6V DC, 60 amps. (Stock Honda Alternator Output )
  • 9"W X 8"L X 3 3/4"H
  • Mfr. 2 year warranty.
I used this unit for one car show (Lowrider Show - Miami '05) The unit powered my 1000 watt system, LED underbody on flicker music mode, Halos, Two TV's and Foglights for about 3 hours.. Turned it off for an hour and ran it again continuously for 4 more hours..
The unit NEVER flickered or even heated up.. It plugs in directly to a wall outlet and converters the power into the type of power the car uses to drive its electronics. A must for shows that do not allow you to use battery power nor turn on the car..
Instructions for use: Simply remove the battery terminals and plug them into the converters red and black gauged wires. Then simply ground the black wires to the chassis ground.. Power up the unit and you are good to go!
OPTINAL CHARGER WIZARD INCLUDED - Monitors car battery and charges to remain at full capacity. Retails for 29.99
Old Feb 20, 2005
o2civic's Avatar
pics of converter..
File Type: jpg
File Type: jpg
Old Feb 21, 2005
o2civic's Avatar
tttt
Old Mar 18, 2005
o2civic's Avatar
ttt-t
Old Mar 19, 2005
o2civic's Avatar
Old Mar 27, 2005
o2civic's Avatar
ttt-t
Old May 8, 2005
o2civic's Avatar
ttttt =)
Old May 8, 2005
o2civic's Avatar
tttt
Old Jun 15, 2005
o2civic's Avatar
tttt
Old Jun 25, 2005
o2civic's Avatar
tttt
Old Jul 16, 2005
o2civic's Avatar
ttt.. just cleaning out my closets.....
Old Jul 17, 2005
o2civic's Avatar
hmmm ttt
Old Jul 18, 2005
diskreet's Avatar
good product just I don't need
Old Jul 26, 2005
o2civic's Avatar
fffff
bugginb
Nov 3, 2001 08:41 PM
bugginb
Detailing
Nov 3, 2001 08:36 PM
SILVERCASE
Sep 25, 2001 08:34 PM
SILVERCASE
Aug 2, 2001 02:19 AM
