Q? w/ 11.5:1
Old Dec 31, 2001
Roy's Avatar
Roy
Roy is an unknown quantity at this point
Q? w/ 11.5:1
if you run a compression this high, is it still safe to run off of 91 oct w/o an octane booster... and still aviod dentination?
Old Dec 31, 2001
mattskav's Avatar
mattskav is an unknown quantity at this point
yeah, if the vehicle is timed right.... in our cars the timing is so mild that you can probably run 11.5:1 without any problems on 93 would be my bet.
I think these cars have a knock sensor too - so you should have no troubles.
Old Dec 31, 2001
1973's Avatar
1973 is an unknown quantity at this point
i would run at least a 93 to be safe, with that compression ratio you might at well go higher w/ octane boosters or pre-mixed race gas, you will fly...it's expensive but so is building a 2k1 engine to run 11.5:1...can our cylinder walls handle that????
Old Dec 31, 2001
Roy's Avatar
Roy
thanks fellas, as of right now... there aren't enough parts out to turn our motors into beasts. Just getting an idea on what our motors are capable of.
LS-Vtec 99hatch
Oct 15, 2012 11:40 PM
ThomasH
Engine Swaps
Nov 27, 2008 12:34 AM
7th_gear
Sep 12, 2008 01:22 PM
