Are MTX amps good?
Old Feb 18, 2005
mattnyc's Avatar
mattnyc is an unknown quantity at this point
Are MTX amps good?
I couldnt pass this deal up on ebay. Retail $299, my price $81!
But it is refurbished, nothing wrong with that. his ebay rating was 100% at 5500 transactions.
here are the specs
http://www.mtx.com/caraudio/products...rs/mxa4004.cfm
Power Output:
50 Watts RMS x 4 channels at 4 Ohms ≤ 1% THD+N
Signal-to-Noise Ratio:
80 dBA (reference: 1 W output)
Additional Power Output:
100 Watts RMS x 4 channels at 2 Ohms ≤ 1% THD+N
200 Watts RMS x 2 channels bridged at 4 Ohms ≤ 1% THD+N
THD+N (Distortion):
<0.25% (reference: 1 W output)
Frequency Response:
20 Hz to 20 kHz (-3dB)
Maximum Input Signal:
5V
Maximum Sensitivity:
100mV
Dimensions:
14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Old Feb 18, 2005
tripledoublegs's Avatar
Euro-Spec
S/N ratio is kinda low.
Old Feb 18, 2005
Mystic3030's Avatar
Yup, i'm an A$$hole.
Not a fan of MTX...kinda low end...but whatever floats your boat.
Old Feb 18, 2005
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
SImple. Try it out, if you don't how it sounds, relist it for more than you paid.
Old Feb 18, 2005
alex053's Avatar
good amp that will probly do closer to 70 watts per channel with SN much lower than listed...new ones come with a test sheet. they are made here in tempe and that is an awesome price for a name brand amp
Old Feb 18, 2005
mattnyc's Avatar
Mine will come with a "birth sheet" as well. They are direct from MTX, refurbished. I have no gripes with smal surface scratches when i paid less than half retail and have full mtx warranty.
I truly think mtx is a good brand. When i get the birth sheet i will try to post it up but they test the amp at 12 volts, which is norm in daily operation, not the 14 volt everyone else posts.
Spoke to a installer at Circuit city who was actually knowleadgable. and he is doing the install on the 26th.
Old Feb 18, 2005
mtx used to be good back in the day, now they're considered on the low side. I had one, worked fine for a year, still have it somewhere.
Old Feb 19, 2005
alex053's Avatar
i used to work at mtx w00t!
Old Feb 21, 2005
IronFist's Avatar
I like mine. Good customer service when you call their hotline, too.
Old Feb 22, 2005
Dlmille's Avatar
Dlmille is an unknown quantity at this point
MTX is a great product manufacture my MITech. I've been through numerous MTX products as I am always changing things and have been very pleased with their performance. I love my 901D amplifier, crack it all day and it still keeps ticking.
Old Feb 24, 2005
mattnyc's Avatar
Received my MTX amps and it came refurbished from the MTX factory with a Inspection Birth Certificate...
Perfect World Specs
Power output 50 W @ 4ohms <1% THD+N
Signal to Noise Ratio 80 dBA
THD+N (Distortion) .25% Reference 1W Output
Birth Sheet Measured Output at 12volts
507 Watts RMS all channels @ 2ohms
Signal to noise ratio 98dBr
THD+N .042%
^^ not a typo, compared to .25 on the web site.
Old Feb 25, 2005
Slawek's Avatar
Proudly Canadian
Slawek is an unknown quantity at this point
no, mtx is not good.
invest a little coin, get yourself a JL amp
Old Feb 25, 2005
Slawek's Avatar
Proudly Canadian
like a 250/1 or something, u will never regret it
Old Feb 27, 2005
mattnyc's Avatar
I got the mtx amp installed and I added a 10" amped-sub last minute.
It thumps man! Its not obnoxious where people can hear me 5 blocks away, but when you are inside it is just too sweeeet. The best part is that everything is under 2 yr Circuit city warranty. I got luck cuz my circuit city has people who knows what they are doing. The amp, sub, and headunit were tuned to my tastes.
http://www.circuitcity.com/rpsm/oid/...Review.do#tabs
Old Mar 1, 2005
MassMayhem's Avatar
MassMayhem is an unknown quantity at this point
Cicuit City knows what they are doing? Wow, hell has frozen over. MTX no good, Audiobahn even worse.
Old Mar 7, 2005
Dlmille's Avatar
Hmmm, for the money I'd rather have MTX over JL anyday. More performance for the money and just as good quality, IMO. I've owned some JL equipment and ended up going back to MTX. I could just be biased toward a product I've always liked. However, JL is great equipment. Just feel it's a little overpriced for what you get.
Old Mar 7, 2005
jttegx's Avatar
OMNES AD UNUM
i would say if you got the bucks for JL equipment, go for it. if you dont care or appreciate your music as much as other things, then JL wouldnt be on your list.
more performance and just as good quality? a JL 10" sub rated at 200rms will own an mtx sub thats 10" rated at 200rms in any performance catergory.
Old Mar 7, 2005
southwest713's Avatar
southwest713 is an unknown quantity at this point
i think mtx is pretty good i have the thunder 404 pushing koda components and the 801d pushing 2 shivas and they both sound great...they're underrated too
Old Mar 8, 2005
Dlmille's Avatar
Sure, JL if you have the money. Bang for you buck, I'll take MTX anyday!
Old Mar 8, 2005
J187's Avatar
Whoa, when you're done with the crack pipe, pass it over. You think MTX offers just as much quality as JL Audio? You need to take another look. I have owned and install both MTX and JL audio and I can tell you it is a night and day difference my friend. Build quality and sound quality alike. I'd even go so far as to say that MTX is even comparable for the money, despite JL's much higher price, the quality/dollar ratio is STILL in JL's favor IMHO. I'm not saying MTX is garbage, I'm just saying that if you wanna save the dough, fine. Just don't fool yourself into thinking you got JL quality.
Old Mar 8, 2005
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
MTX was the good stuff back in the day, but now a days they aer pushing sales at Best Buy and have lowered their quality of items. If you want to stay in the MTX brand, move over to XTANT, they are a subsidiary company of MTX, now their stuff is high-end audio equipment., it is definetely NOT something you would see at Best Buy or Circuit City.
Old Mar 8, 2005
J187's Avatar
I have been pretty impressed by Xtant, but that is one company I would lmake the argument is overpriced.
Old Mar 8, 2005
Dlmille's Avatar
Well, not to start an argument. All I was saying that to most consumers, many may not be able to tell the difference between a good mtx setup and a JL setup. Granted different products, different power, different specs yield different results. I'm just saying that if someone doesn't want to spend a lot of money they can get alot of bang for their buck out of MTX. I love both brands, just in my experience I enjoyed MTX better, this is a personal preference though everyone hears things different.
Coustic, MTX, and Xtant are all made by Miteck in Pheonix Arizona at the same plant. Just different parts and specs in each product. I agree, Xtant is extremely overpriced. However, have to love their 2 channel amp that is the size of a CD jewel case.
Old Mar 8, 2005
Dlmille's Avatar
I guess, I agree with everything you are saying J187. I would say if money wasn't an issue and you wanted the cleanest sound. I would go with the JL setup.
Old Mar 8, 2005
J187's Avatar
And for the money, I wouldn't hesitate to say MTX get the job done pretty well too. It was only the just as good quality part that got me. You are right about a lot of consumers wasting their money on high end stuff when they don't have an ear for music. I don't want to hijack this thread, so I'll start another post to tell a funny story. Check it out, it's right along the lines of what you are saying. BTW, if I ever tell you to put down the crack pipe, that's my humor side, not my ******* side. I never mean anything in a condesending way.
Old Mar 8, 2005
mattnyc's Avatar
I have the MTX 4004 and I love them. I do have a shitty 10" Audiobahn sub with self contained amp, but i love the setup.
Does it sound as nice as a custom box for 2 10W7 JL's and JL Components powered by a top shelf rockford amp? Prob not, but i saved myself 70% of what that would have cost me in a daily beater civic.
no complaints here.
Old Mar 10, 2005
Dlmille's Avatar
No offense taken J187! Every now and then a good hit off the ole crack pipe will keep us all grounded!! haha!
Old Mar 10, 2005
J187's Avatar
As funny as this is, a buddy Came by yesterday with his 89 civic, I haven't seen in a long time. I went for a ride with him. His bass was hitting pretty tight, so I asked him what he had - 2 10" Boston accoustics powered by a, you've guessed it, MTX amp.
Old Mar 10, 2005
Dlmille's Avatar
haha, honestly you just never know these days
I've heard systems that beat like heck and sound awesome and then you ask what they are using and it's some assortment of crap just installed really well and then others that people have spent $$$ on and had bad installs and it sounded like crap.
You just never know!
Old Apr 22, 2005
mykungfuisthebest's Avatar
mykungfuisthebest is an unknown quantity at this point
almost every popular auto company has gone to ****... however any mtx stuff up till last 2 years is incredible i have a mtx thunder 8502 amp running 2 mtx 8000 amps and my audio guy who has been doing this since the dawn of car audio rants and raves about it... he has 2 RFL spl comp subs in his truck... ive only seen louder systems than mine at some shows, and i personaly dont think the sound quality is as good = )
