exhaust sound?
Old Feb 13, 2005
allmotor's Avatar
nor cal 7thgens
exhaust sound?
kind of a weird question but when i wanted to run off the cat (vp) i took off my exhaust and wanted to see how it sounded like and if it felt different. I Didnt really like it so i put the two bolts on and connected the exhaust back on. Now whenever i rev up past 4000 or start in 1st it makes a weird loud rattle and i know its the bolts but i tightened them? Has this every happened to anyone? Any help would be great.
Old Feb 13, 2005
hotrodcivic2004's Avatar
my civic has no boost
um i dont quite know what u did.......u took the entire exhaust system off and then drove around?
Old Feb 13, 2005
streetglower's Avatar
you have something loose or something hitting? Go back and check everything and see where is it hitting.
Old Feb 13, 2005
Nodnero's Avatar
Do you have an upgraded rear sway? Maybe you didnt tighten the bolts tight enough and the springs are loose? Did you put the springs back on over the bolts?
Old Feb 13, 2005
yur shield over yur cat might be bent and touching the cat.......yeah yur rear section might be contacting your sway bar. just check everything it sgot to be something loose.
Old Feb 13, 2005
allmotor's Avatar
nor cal 7thgens
naw i didnt remove my cat just unbolted the exhuast and moved it off the side. So ur saying its probably hittin something? and yeah the springs are over the bolts.
Old Feb 14, 2005
look under there and see.
Old Feb 14, 2005
KDawg88's Avatar
KDawg88 is an unknown quantity at this point
Check to see if there are pebbles in the heat shield. When I had my 92 vic I had that exact problem...no noise when drivin easy or idling, but the moment I revved her up it started rattling. Maybe you got some debris in the heat shield when you removed the exhaust. Bad news is you may have to take it down again to find out.
Old Feb 14, 2005
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
It was not a good idea to drive around with your exhaust unbolted. Your car need some sort of back pressure to run correctly. You prolly didnt like the feel cause the car was slower and losing tons of power off the line due to 0 back pressure. Retorque all your bolts then if that dosent fix it, check the heat sheilds. You may have gotten something down in your exhaust pipe if you drove it around with the exhaust unbolted and just sitting there wide open. Good luck and i hope you fix the problem. Next time your going to take your exhaust off, dont even start your car, its not the best idea.
Old Feb 15, 2005
2K1Civic17"Gabe's Avatar
I thought this was a funny thread. I took my exhaust off, put it back on, now its rattling. First thing I woulda done if it rattled was redo everything. Good luck.
Old Feb 15, 2005
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
maybe that rattle is because your car is damn loud after removing the exhaust catback? the vibration of the loud notes comming out of your "cat" piece is probably it. i say jack up the car, have someone rev it a little and try to spot the problem.
Old Feb 15, 2005
VegasJones's Avatar
VegasJones is an unknown quantity at this point
I think it's funny that someone would acutually unbolt their catback and drive around...lol...sorry man, i'm not tryin' to be an ***, just never heard of anyone doing that...wonder what it would sound like if you just unbolted the header and took off for a little spin
Old Feb 16, 2005
teamPR0's Avatar
Won By One
teamPR0 is an unknown quantity at this point
dynamat your exhaust. hahaha
Old Feb 16, 2005
...haha
Old Feb 17, 2005
Al Gore FTW's Avatar
jdmtytedoridori
my friend with an 00 civic ex did that once. but his didn't rattle after we hooked it back up. lol
Old Feb 17, 2005
Rotarynomore's Avatar
Rotarynomore is an unknown quantity at this point
rattle
besides quiting the exhaust part of the function of the exhaust is to route the heat away from the engine. While you were driving around with y oru exhaust unbolted there is a good chance you melted something and now it's loose. check fo rany rubber or plastic parts neer where the cat bolts up to the exhaust.
15EXCoupe
Jul 30, 2015 12:59 PM
Misfit2613
Jul 30, 2015 09:49 AM
S1N7H3T1C
Jul 21, 2015 05:20 AM
hayden55
Jul 8, 2015 11:38 PM
fvckbg
Jul 7, 2015 07:08 PM
