Drag Question
Old Feb 13, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Drag Question
When the drag strips open back up this season, it'll be my first drag season ever. This is gonna sound like a n00b question, but which will work better? 14" steelies mounted with DR's or 17x7's with street tires? Stock steelies are like what, 5" wide? Given that, vs 7" tires with street tires, taken tread into consideration, are about 5" wide as well right minus water tread? But DR's rubber compund are softer right? Ahhh, okay, some plz help.
Old Feb 13, 2005
S2000man01's Avatar
O RLY
steelies with DR's would be better.
first cuz they are DR's. second, because the smaller rim/tires will make you accelerate faster than the 17 inch rim/tires.
Old Feb 13, 2005
hustlelikem0fo's Avatar
or you can get some wider 15s.... like 15X7. but DRs would be better like s2k said
Old Feb 13, 2005
Sweet2K4EX's Avatar
Sweet2K4EX is an unknown quantity at this point
Yeah, go for the smaller rim and tire combo. It will give you a little more torgue witch will help you get off the line and a little help down the track. Speed wise you will be about the same. Plus the steelies should be lighter.
Old Feb 13, 2005
Redline04's Avatar
AKA Mr. 60ft. Not to be confused with Civic_Redline
Redline04 is an unknown quantity at this point
hey you should check these out for your DR's
14x6 only 9.3lbs for $120 a piece.
I wanna get some for mine.
Stock 14's weigh around 15lbs
http://www.tirerack.com/servlet/Call...filterSpecial=
Old Feb 13, 2005
Pb4uGo's Avatar
Pb4uGo is an unknown quantity at this point
14x6 the stock Miata wheels are an awesome choice and can be found in yards around me for usually about $20 a wheelat a tic under 12lbs a piece.
my favorite cheap lightweight wheels for 5-lug are the Mazda Millenia wheels, 15's coming in at about 13lbs.
Those Kosei's are nice, you can also check out the Kazera's in 15" that are almost 11lbs and really quite cheap. The one's I'm talking about you can find on Discount Tire's website for Miata fitment.
Old Feb 14, 2005
GuliziaN's Avatar
Powered by Honda...
GuliziaN will become famous soon enoughGuliziaN will become famous soon enough
Nice find Redline... I wish I had money to get a set of track wheels on top of street wheels...
Old Feb 19, 2005
00celicagts6spd's Avatar
I personally like the subzero's.
the 14's would be better like everyone said because of dr's. also the smaller diameter will put the weight of the tire closer to the center and cut down it's rotational mass.
also I'd suggest the BFG g-force dr's.
you'll want to run then at 12-15 psi for maximum traction. 12 for cold days and 15 for hot days.
Old Feb 23, 2005
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
I would recommend rotas w/ the DR's. Rotas because they are cheap, lightweight, and look sweet as hell.
Old Feb 23, 2005
scatman's Avatar
Still in the game...
steelies/dr's > 17's
Old Feb 23, 2005
Boosting Daily
Now here comes the real question. Do you think the stock axles could handle being launched on DR's w/ boost? I'm worried about stripping the splines out on the drive axles. Knowing my luck, i'd strip out the splines on the output shafts in the transaxle.
Old Feb 23, 2005
^^yes...if they will handle nitrous out of the hole they'll definitely handle the boost out of the hole.
Old Feb 27, 2005
gsrchad's Avatar
gsrchad is an unknown quantity at this point
the lbs of air in the tires here doesnt make senes... if you want them to be close and change the tire pressure to accomidate the change in temperature outside, wouldnt the pressure in the tire on hot day be lower since hot air expands? say 15 on cold day and 12 on hot day....?
Old Mar 2, 2005
I've done this many many times with these tires. I also pull some very good 60's running what I suggested.
you can follow my suggestion or not, your choice.
SuperNova18
24
Sep 2, 2019 10:46 PM
lexus300
Wheels and Tires
Aug 16, 2015 04:31 PM
lexus300
Aug 16, 2015 04:28 PM
Inkubus
Wheels and Tires
Aug 13, 2015 05:01 PM
krazykoncepts
Jul 14, 2015 01:55 PM
