Slim line fan?
Old Feb 11, 2005
HyaBoosta's Avatar
Slim line fan?
does anyone know or tried using a slim line fan on our cars? I could use the extra room in the engine bay for the IC piping.
Old Feb 11, 2005
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
FAL part number 190, with a letter on the end for color, i.e. 190B for blue. Two will fit, have to do very minor trimming. Flows 10x more air than stock.
Old Feb 11, 2005
HyaBoosta's Avatar
does fal make the slimline fan?
Old Feb 11, 2005
First to spool
The FAL fan is better than the one you posted. It's as slim as you can get.
Old Feb 12, 2005
HyaBoosta's Avatar
where did you pick it up from and about how much?
Old Feb 12, 2005
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
those are good ones and you can get one at overboost i believe
Old Feb 13, 2005
First to spool
FAL Fan
Old Feb 13, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
You bought 2 of those for $270 a piece?
Old Feb 13, 2005
First to spool
No, I paid significantly less than $270 for two fans. Got to love working at a speed shop.
Old Feb 13, 2005
C2i0v0i1C's Avatar
SuperMODrizd
i paid 120 for a flexalite i think its called
Old Feb 13, 2005
HyaBoosta's Avatar
the ones I show are 60 each. anyone know how much our stock fans flow?
Old Feb 13, 2005
First to spool
About 450cfm.
Old Feb 14, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
anyone know whch one to get for an 02+ si?
Old Feb 14, 2005
HyaBoosta's Avatar
this fan is said to flow 1400cfm
Old Feb 14, 2005
TheSmuggler's Avatar
so does this plus right into our normal fan harness ir hows this work?
Old Feb 14, 2005
First to spool
You use the plug from your old fan. Cut it off, use a solder or crimp connection on the two wires, then plug it in like the stock fan. ECU controlled.
Old Feb 14, 2005
Well I know the ecu controlls it I was hoping I wouldent have to solder.. *looks at burnt motherboard* :ROFL:
Old Feb 14, 2005
First to spool
Then don't, use a crimp connection. For something like this that isn't a sensor, it will work perfectly.
Old Feb 16, 2005
Drk01Civic's Avatar
I wonder if you could use the FAL dual fan for the Integra. What exactly did you trim to make those Focus fans fit?
Old Feb 16, 2005
First to spool
On one fan, nothing. On the fan mounted on the passenger side, I had to trim a rectangle 2" long by .75" deep in the edge of the plastic shroud to fit the bottom coolant hose to the motor. I mounted it with a combination of the radiator zip ties designed to mount fans and two screws on each screwed right through the plastic shroud.
The trimming took less than 5 minutes with a Dremel, and doesn't affect the fan's function at all.
As for fitting another fan, just measure it. Fans are fans, and most FAL's flow the same and use the same motor. The only difference is the shroud size. I used Focus fans because that is what we had in stock at the shop, I'm sure there are many others that would work.
Old Feb 16, 2005
Drk01Civic's Avatar
Ahhhh, I see. It was all due to availability. I think I am going to buy the dual fan for the Integra and adapt that. Thanks for the info.
Old Feb 16, 2005
abmerop18's Avatar
Jam out with your clam out.
I dont know if they are any good, but I saw this on H-T and thought you might be interested
http://honda-tech.com/zerothread?id=1150195
Green02civic
Jul 27, 2015 10:48 PM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
