TSX K24A2 Engine Swap into 7th Gen Civic
Old Feb 10, 2005
bogmancometh's Avatar
bogmancometh is an unknown quantity at this point
1. Can a TSX Engine and Tranny be swapped into a 7th Gen Civic?
Current civic is an automatic and will be staying automatic.
2. Other than the engine swap is there anything else necessary or wise to consider changing when dropping a 200HP engine into a Civic?
Thanks,
This is my second post ever very new to this idea, but dropping a 200HP engine into a Civic sounds fun
Old Feb 10, 2005
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
auto wil fit had the manual but pretty much the same it bolted up perfect with some mods needed puls hard and its fast
Old Feb 10, 2005
Ekonetics's Avatar
Ekonetics is an unknown quantity at this point
what mounts do you use to do the swap?
Old Feb 10, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
according to Hasport, if you plan on putting an auto tranny with a swap, it will not last very long
Old Feb 10, 2005
cambo's Avatar
I wish I was asian
What did u do to overcome the throttle-by-wire set-up used by the K24A2?
Old Feb 10, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Probably a different throttle body.
Old Feb 10, 2005
02sleeper's Avatar
ok i had another throttle body because i used a k20 head off a type r
Old Feb 10, 2005
Ekonetics's Avatar
Old Feb 10, 2005
cambo's Avatar
I wish I was asian
what ECU are you using?
Old Feb 10, 2005
doubledeuce2k2's Avatar
can't use tsx ecu b/c of the throttle by wire, i have heard. probably k-pro'd ecu of some sort
Old Feb 10, 2005
02sleeper's Avatar
k pro and enjo mounts
Old Feb 11, 2005
Why would the Auto Tranny from the TSX not last very long? And is this for any swap or just the TSX swap?
Old Feb 12, 2005
HondaLuver's Avatar
Its a celebration bitches!
the tsx auto tranny will not fit... don't be a bitch and learn stick. the enjo mounts work, but the hasport passanger mount will have to be changed for a stock k24 mount, it will fit, with the k24 you will need a si or rsx tranny, it will fit with the enjo or hasport mounts.
you will need to get k pro, and you have to use a rsx or si TB to bypass the DBW. and the kpro is because you havbe to bypass the drive by wire. hondata does not want to need with drive by wire...
please search 7thgen and clubrsx, k20a.org, k-series.com, honda-tech, and do more research before you ask questions that have been beaten to death...
Old Feb 12, 2005
As I said I'm new and I have done plenty of searches. Hondaluver no need to be a *****
Old Feb 12, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
no idea. ask brian g from hasport ... he's the one who said it ;P
Old Feb 12, 2005
HondaLuver's Avatar
sorry, but its like every day, a diffrent swap question every day... that has been covered, you should look on ephatch, they talk about it alot over there...
Old Feb 13, 2005
Thanks, I can understand it just came off kind of harsh, I appreciate the help.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
shawe90
Apr 14, 2015 07:10 PM
Myredjonda
Apr 14, 2015 07:00 PM
fordfocussucks
Nov 8, 2001 11:03 AM
