Fuel Pressure Regulator for WHEN BOOSTED????
Old Feb 5, 2005
BudDyLeEBoOsteD's Avatar
BudDyLeEBoOsteD has a little shameless behaviour in the past
If I have my stock injectors w/ the SAFC set plus 20... and it still runs lean...
(If i add a Fuel Pressure Regulator..) would that help fix the problem.....
would it be good enough to run 7-8 psi?
Old Feb 5, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Probably not. Stock injectors are way insufficient for 7-8. Go to RC injector website and use there injector selection chart. 310s might be about right. If you go any bigger and try to correct for it off boost you will trip a CEL. BTW a boost referencing regulator is a good idea still.
Old Feb 5, 2005
Well first you need to convert to a return style fuel system. Streetlevelperformance.com sells that kit for our cars. Then you can add the fpr and add more fuel. And safc isn't the best tuning tool either. Why not get the e-manage?
Old Feb 5, 2005
civic01vtec's Avatar
a fpr will not do anything with a stock intank fuel pump. The stock fuel pump has a built it fpr. You need to upgrade the intank pump, then install a fpr. Also, you will need to modify the fuel rail to run a return line back to the tank for a return fuel system.
Then when that is done..........if you have a wideband, then street tune it......if not......limp you car over to a shop with a dyno and tune it.
Old Feb 5, 2005
Yea.. I have the RC 310's in the trunk of my car... the only thing was that I put them in there once. and they didnt fit.. it was hizzin and leakin everywhere. The stock Rail aint big enough......... So if i by the return Fuel system kit.... the stock Injectors would be able to hold the psi's?
Now let me ask you this.. cuz i was about to have these people create a Fuel Rail Custom, If I was able to stick dont RC 310's in there right with the new rail... Would that be all i needed.. or would i still need that conversion kit??????????
Old Feb 5, 2005
i still don't know why you didn't get the type s injectors...........they are rated as 330's i believe.
anyway.......it might be cheaper to buy type s injectors than to have a shop custom make a rail for you.
Let me ask you this............do you still have the stock intank fuel pump ????
Old Feb 5, 2005
02fpcivic's Avatar
no stock injectors will not. you can prob get away with the custom rail and no FPR but you should do everything including the pump if you want to play it real safe.
Old Feb 5, 2005
Ok so,. Custom Rail, My RC 310's,255lph, and SAFCII,. I should be fine??????????????????
Old Feb 5, 2005
02fpcivic's Avatar
probably but without a FPR you will only be able to run the fuel pressure at around 43lbs. You will get more out of the setup if you lose the in tank FPR and go with an external, boost referencing one. You will be able to crank up the pressure and get more fuel from the injectors. You can push RCs pretty hard.
alxz310
Jul 30, 2015 12:18 PM
mistermenphis22
Jul 13, 2015 04:43 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
AaronSorenson
Jul 7, 2015 09:40 PM
fvckbg
Jul 7, 2015 07:08 PM
