FS: A brand new, just test fitted, Dezod SS turbo manifold
Old Jan 26, 2005
dezod's Avatar
7thgen Power Maker
Will fit automajic & will fit 5 spd, but requires slave cylinder to be moved for down pipe clearence. This was our first design. We made changes to accomodate for the 5 spd as well with our slightly new manifold design. Lookin for $380 FIRM. plus s&h
*T3 Turbo 4 bolt Footed
*Fits All D17 Engines
*Uses Externally Wastegated TiAL 38mm wastegate
*Retains A/C & P/S components
*TIG welded 304 Stainless Steel
Looks like this:
What it looks like installed.........look!
Old Jan 26, 2005
AlpineCivic's Avatar
So this will fit a 5 spd but the slave cylinder needs to be moved? (just want to get that clear)
Old Jan 26, 2005
dezod's Avatar
7thgen Power Maker
Correct.
Old Jan 28, 2005
dezod's Avatar
7thgen Power Maker
Needs to go!!!
Old Jan 28, 2005
dezod's Avatar
7thgen Power Maker
This is the actual piece.
File Type: jpg
Old Jan 28, 2005
gotti's Avatar
why does it look cracked at every drilled hole?
Old Jan 28, 2005
dezod's Avatar
7thgen Power Maker
NooB!
It is cut like that for thermal expansion purposes.
Originally Posted by dezod
Thermal expansion........
The flange is made of mild steel, rest of mani is stainless. They expand at different rates. If the bolt holes are not cut, with them expanding at different rates, it can snap a stud right off the motor.
Old Jan 29, 2005
dezod's Avatar
7thgen Power Maker
up up up
Old Jan 31, 2005
dezod's Avatar
7thgen Power Maker
bump for an awesome deal
Old Feb 1, 2005
dezod's Avatar
7thgen Power Maker
up up up
Old Feb 1, 2005
dezod's Avatar
7thgen Power Maker
must go!
Old Feb 2, 2005
dezod's Avatar
7thgen Power Maker
Bump
Old Feb 2, 2005
dezod's Avatar
7thgen Power Maker
This manifold is such a deal.....
Old Feb 3, 2005
dezod's Avatar
7thgen Power Maker
Turbo manifold........great start to your custom turbo set-up
Old Feb 3, 2005
dezod's Avatar
7thgen Power Maker
This manifold never had a turbo or wastegate mounted to it. Just mounted on the motor to see where it would place the down pipe on a 5 spd. This is a twin to the one pictured above on our Civic.
Old Feb 3, 2005
dezod's Avatar
7thgen Power Maker
***Sale pending***
Old Feb 3, 2005
dannn's Avatar
unique conformist
dannn will become famous soon enough
cmon somone pick this up!
Old Feb 4, 2005
dezod's Avatar
7thgen Power Maker
*sold*
Dann thanks for the good luck!
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
elitezdc5
May 26, 2015 05:46 PM
Supramk3
May 11, 2015 07:55 PM
ORskier
May 3, 2015 12:54 PM
