SRI rubbing against hood
Old Jan 25, 2005
MegaHurtz's Avatar
I just installed a short ram intake (generic brand) and it rubs a litle bit right in the middle of my hood... is there anything I can do to hold it down or keep it from rubbing?
Old Jan 25, 2005
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
I had the same problem
if the first engine mount is shaped like a U you can file into the U a little bit more and shwish in down on the the engine some more...
Old Jan 25, 2005
MegaHurtz's Avatar
wha?
Old Jan 25, 2005
4jacks's Avatar
The first engine mount on the SRI ... it's shaped like a U and the bolt that holds in into the mount slides into the U... well file the sucker so the slot in the U goes deeper.. then you can lower the SRI however much you file...
Also make sure the connection to the engine block is as snug as it can go.
Old Jan 25, 2005
MegaHurtz's Avatar
i dont have any mount for anything, you have pics?
mine only clamps on to the throttle body with a ring clamp, there is no other anthing holding it down anywhere
Old Jan 25, 2005
4jacks's Avatar
ROFL ... Cool someone actually has a cheaper eBay air intake than Mine !!
I can try to take a pic... but mine broke off... so it's the same thing now..
I still have to fabricat it..
you may have to cut a 1/2 inch or so off the throttle body end.
Old Jan 25, 2005
MegaHurtz's Avatar
will consider that, thx!
Old Jan 26, 2005
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
Dang. if nothing else just put a big hose clamp on the intake, and clamp on a little hanger. not too hard.
Old Jan 26, 2005
PunkingCivic's Avatar
I need TP for my bunghole
is it rubbing right above the intake manifold?
If so, then push it down more if possible
there might still be a gap between the intake tube and the throddle body.
Push until the intake tube and the T/B touch
then retighten the clamps
Old Jan 26, 2005
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
just buy some exhaust pipe cutters and cut off however much you need for it to not rub. I had to do the same to my turbo charge pipe. I cut off about 1.5 in. so the hood wouldn't bump it.
Old Jan 27, 2005
MegaHurtz's Avatar
there is no room to cut it off i checked
It doesn't rub on the intake manifold, just on the hood
I'll play with it tomorrow and see what I can do
Old Jan 27, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
i had the same problem.. i took a hacksaw and just cut off about 1/2 an inch from where it connects to the throttle body.. i wasnt sure if it would make it too short.. it didnt.. close.. but not too short..
the two dots are where mine was rubbing.. the line is where i cut it.. the clamp now clamps about .0001 inches from the end of it..
you might also want to reapaint it.. it will pick up a deeper sound
Old Jan 27, 2005
4jacks's Avatar
That looks tight... love your strut bar..
My friggin SRI isn't even flat like that ... it's an upward V shape... POS
Old Jan 27, 2005
MishBallzEM2's Avatar
I'm The Ballz Of 7th Gen
MishBallzEM2 is an unknown quantity at this point
i did that same thing with my first intake and it worked....
but then i just went out and bought one that fit
Old Jan 27, 2005
bradmanuwf's Avatar
Just buy this and use only the top piece unless you want the cold air intake. But then you'll suck up water, so I wouldn't use it. The top piece fits just fine, no rubbing, and its the same as an AEM intake, just no stickers...lol
http://cgi.ebay.com/ebaymotors/ws/eB...950548332&rd=1
Old Jan 27, 2005
bradmanuwf's Avatar
What kind of intake is that? It looks like plasitc....is it? Never seen one like that before.
Old Jan 27, 2005
4jacks's Avatar
lol... dude it's painted black
Old Jan 27, 2005
bradmanuwf's Avatar
it still looks like plastic...lol
Old Jan 27, 2005
4jacks's Avatar
Yeah... looks like a peice of plastic... painted black =P
Old Jan 27, 2005
againifall's Avatar
Go Team Venture!
nope its metal... its the black one on ebay.. theres only one.. i cut it, sanded it, then painted it again.. it sounds better painted.. strange as that may sound.. its less "tinny" now.. if thats a word
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
rnaodm
Sep 21, 2015 12:42 PM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
