K24 in a 01 CIVIC?
K24 in a 01 CIVIC?
hey i was wondering, since you can get a k20 in a 01 Vic almost with no problems, then can you get a k24 in with some mods. i found a CRVs motor at a place where they sell used motors and parts. its very cleen in a warehouse and isnt selling cuz noone needs a k24. but i would like to buy it cuz my friend works there and he can get the 02 motor for only $700. thats a damn deal.its $1300 if you arent employed there. let me know if its possible. tnx.
sure it can be done......k24 block with a k20 head. It is called a frankenstein. Talk to HondaLuver......he was gonna do it, he researched and knows alot about it.
7thgens official a$$hole
you would have to get custom mounts and sub frame made, you don't need to do a k20 head swap, but the k20 head is vtec where the k24 is not. its kinda like how people used to but b16/b18 heads on b20's. just a new generation of tuning. alot of pro racers are running k24 w k20 head.
PC Tech / Autocrosser
Along the same lines, since the K24 is a taller block and if you wanted to start with just the K24 and later swap the K20 head, I was curious if the EM2 hood would be able to close with the K24 in it. I know you already have to notch the hood for the power steering to clear.
Boosted Auto Sedan Project In Progress
i thought k24's where vtec i now the k24 from a tsx i had was vtec i just put a k20a head on it because it flows alot better. it hauls. i had it in my civic em2 for about two months and i slide and put it in a ditch because of the f***ing snow but i got some insurance money and my new project is underway
Powered by Honda...
Originally Posted by 01-BLUEBird
yeah i just needed to know if it was possible without it having to become a major project. a swap and a little cutting is what im looking 4.
Originally Posted by HondaLuver
yes with the enjo mounts
, and when you change heads it does not change the height of the engine
Ok, I thought the head height was different between the k24 and k20, so then really it's only the block that's taller and not the head.
Turbos, Engines, Chassis and Suspension Tech
Originally Posted by PrecisnTec
K24 Vtec is only available in the TSX. It has been said that you can use this head and then use a Type-S intake and throttle body to make it work.
Cilvic
Nov 15, 2001 04:54 PM
WeRkX
Nov 1, 2001 10:33 PM
