What THE FUKKing HELL!!!
Old Jan 22, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
ok last night i jack up car and well everything i awanted to get completee didnt work
how the fuc.k do you take off the control arm.. the bolt under the knuckles wouldnt pop out and i didnt wanna use my tie rod sep cause ida ripped the boot (like my tie rod boot is totallly ripped both sides...
went to buy new ones and well i can get the old ones off.
someone help me
also how do you change rear drum shoes??
Old Jan 22, 2005
armieo's Avatar
< My future wife.
Bang the arm downward with a hammer.
Old Jan 22, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
did w/ a sledge..
Old Jan 22, 2005
robbclark1's Avatar
Retired suspension supermod.
The rear drum shoe thing is in the brake section. Are you taking the whole arm off or just the brake hub? If you are taking the whole thing off there are two bolts that go up verticle to the car right behind the jack point. Then you have to removed the rear control arm bolt. I would first remove the two bolts that attach the hub to the control arm then drop the arm. It is really easy. You might need something to extend the socket wrench to get more torque.
Old Jan 22, 2005
tfnaaf's Avatar
BLDNPSI Mod
someone help me
The easiest way to brake the tapper fit is to losen the nut to the end of the stud to protect the threads. Get a hammer and hit VERY hard and exzactly on the SIDE of the control arm where the stud goes thru . If you have a ball pien hammer use the the ball side of the hammer it will direct all the force to a center single point whne the hammer hits. This may take anywhere from 1-5 swings. After the tapper has broken free take nut off rest of the way ....Ta-Da!.
As for brake shoes as rob said... Best way is leave one side on and take other side apart noting how each spring is oriented and reverse procedure to install new shoes
Old Jan 22, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
i just gave up.. ive been up since 6am fri.... didnt sleep last night... until 9am this morn.. im exhausted and pissed
JetsterDajet
52
May 8, 2016 12:11 AM
Dawit Melese
Oct 4, 2015 08:02 PM
RIPSAW
Aug 16, 2015 12:14 PM
JetsterDajet
Aug 15, 2015 08:07 AM
