Helpme....hp Header W/highflow Cat
This should tell you everything. However, I remember some people posting about broken engine mounts a while after they cut them.
http://www.7thgencivic.com/forums/sh...hp+race+header
Unbolt the front motor mount (2 from above 1 from below, and the cross bolt) and slip the header in from below, easy job. If you are like me and your mount was already ripped to crap at stock power with 40k on it, then just fill it full of 3M window weld and let sit for a day or two to cure. $3 polyurethane mount, and you don't have to replace the broken one
. Joined: Jun 2002
.It can still be tight. If it is still not going get a jack under your engine and move it up just a bit.
Originally Posted by djmota
What he said .
yup. just remove the front mount entirely and raise the engine a bit. Its tight and it goes in, in a wierd angle but it will fit without bending or cutting anything.
Hey....I just finished.....its about 2am but I finished........damn I had to push the engine to the back and remove the front engine mount like somebody said......a also unbolted the right mount (passanger side).......I still have to trim that subframe cuz its making my car shake too much.......thanks for all the replays....they helped me a lot the thing that suck is that I get my cat back on tuesday. so, I'm running with just the headers and Highflow cat.......it sounds like **** !!!!!!!
........now I just have to figure out how to cut the subframe where the header its hiting it!!!!!!
Dam HP, you should have gotten the Kamikazi header man, direct bolt on! You shouldnt install anything that you have to cut/shave in order to make it fit IMO. But yea you need to get an 02 sim asap!
Some people say the o2 sim will make the car faster because it affects fuel mapping, but others say that the sims are simply to keep the engine light off, and that it does nothing to improve horsepower. Your thoughts....?
Does nothing for hp. That 02 sensor is only to tell the ecu that your cat is working. The a/f is calculated from a different sensor.
Use a dremel to cut the subframe (with a metal grinding tool).
i didnt install that o2 module the engine light went on sometimes and then back of
and now it doesnt light up anymore so!
Like gearbox says it does nothing fo hp it just to fool you ecu that cat is working
grtz
grtz
i have the same thing you do on my car the light will still come on but only if you race for about a day... when i say day i mean off and on all day long. the light will then come on but if you drive like a grandma (shifting @ 3k) then the light will go off. ive had mine on for about 3 months now and i dont have sims yet. the light will come one but dont freak like they said its just your o2 sensors
jdh022764
18
Nov 3, 2015 06:44 AM
