I got a leak somewhere!!!
Old Jan 19, 2005
rcamp9's Avatar
rcamp9 is an unknown quantity at this point
Angry I got a leak somewhere!!!
About 2 months ago I noticed that when it rained my driver side floor mat got really soaked. I think that it was just water running off of my feet, so I went out and bought those rubber floor mats. Well that other day when it raining hard, I noticed that my floor carpet was soaked again, this time under the mat!
So i guess my question is do any of you have problems with the car leaking? Where should I even start to see where it is coming from? And finally is it difficult to replace the carpet in the car, because my is pretty moldy (I think).
Any help appriciated
Old Jan 19, 2005
vietfob714's Avatar
vietfob714 is an unknown quantity at this point
my gf has the same problem with her 2k3 civic. I'm thinkin its a honda problem but since the car has mods and ****, they blame it on that and dont wanna fix it. My advice is to go to honda cuz i think its a common problem.
Old Jan 19, 2005
rcamp9's Avatar
Come On And Someone Give My Any Insight Into This Problem!!!!!!!!!!!!!!
Old Jan 19, 2005
PunkingCivic's Avatar
I need TP for my bunghole
I remember there being an issue with the gas cap section.
There was gap somewhere.
It was letting water in the car.
Also I recently read where a person was getting water in the door frame and jacked his speakers up.
As for the carpet it shouldn't be that hard. the only pain is taking the seats out front and back.
and if you are gong to do all that, Dynomat the floor boards too!
Just my opinion.
Old Jan 20, 2005
george19's Avatar
george19 is an unknown quantity at this point
I had the same p[roblem.......there was apparently a seal that was broken in the driver side windsheild drain. The water run off from windshiels just came into the car instead. Fixed under warrenty
Old Jan 20, 2005
rcamp9's Avatar
Thanks george19!! unfortantly my car is not under warrenty anymore, but I hate the Honda place by my house (long story) so I don't go there unless I know that it is something easy for them to fix or something they see all the time. I guess I will take it to them and tell them to check the seals in the windshield drains.
Thanks again
Old Jan 20, 2005
slowcivic2die4's Avatar
slowcivic2die4 is an unknown quantity at this point
I had the same problem with my 2k4. It was a mix between the top of the windsheild wasnt caulked right, and the sunroof drain wasnt right. Good luck with it man!!
Old Apr 4, 2005
BuddyB's Avatar
BuddyB is an unknown quantity at this point
Fixed
The wet carpet on driver's side was really annoying me. If you have a sunroof here is the fix.
Remove the plastic panel behind the hood release. Next, remove the two bolts from the hood release switch. Then, remove the one screw from the vertical metal bar. Behind the metal bar are wires. Behind the wires is the drain tube from the sunroof.
The drain tube is split into two pieces. Due to honda's poor design, the tubes became separated. When it rains, the water from the sunroof would drain down this tube and onto the driver's side carpet.
To fix the issue I purchase a 3/4 inch radiator clamp ($.50) and clamped the two hoses together.
I left the car out in the rain, and it has never leaked again. My carpet has been dry ever since I clamped the two hoses together.
Old Apr 4, 2005
BuddyB's Avatar
Sorry for the large photos. I was being lazy and did not have time to crop them. Plus, I was in a rush since I was running out of daylight. I just wanted to post something since I could not find a fix, and I knew a lot of people were having the same problem.
Old Apr 4, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Good Post! Thanks for the pix.
Old Apr 17, 2005
zen_master's Avatar
VERY INTERESTING!
however, can you please zoom out the pics a lil' bit?
the first pic is clear...however, onto the second nad third pic...im confused...
thanx!
Old Apr 18, 2005
zen_master's Avatar
bumped. need help with pics...
Old Apr 23, 2005
BuddyB's Avatar
I got off my lazy butt and fixed the photos for those who do not understand. By the way, my driver's side carpet is still dry.
Old May 5, 2005
red_civic's Avatar
red_civic is an unknown quantity at this point
I noticed my driver side carpet wet after it had rained, two days afte buying the car, but I don't have a sun-roof. Can the leak come from the same place?
Old May 5, 2005
Wolfgang5884's Avatar
thats some great info
Old May 6, 2005
rpannick's Avatar
rpannick is an unknown quantity at this point
The dealer replaced or fixed the plug where the hood cable passes through. No more leaks.
Old May 30, 2005
red_civic's Avatar
after bringing the car for a second time to Honda, Honda called me today that the water leak I have is more serious than they thought. My dealer has been talking to Honda Canada because water is coming is through the welds of the body, from the engine compartment and from underneath the car. The dealer told me that Someone from Honda Canada might have to come down to look at the car...not good news...is there any action I can take? Can I somehow force them to give me a new car ...lol
Old May 30, 2005
tinman's Avatar
Yeah, sounds like they forgot to seal the body when they built it. I'd push for a new one.
It will likely rust out between the welds.
Old May 30, 2005
red_civic's Avatar
how do I go about pushing for a new one?
Old May 30, 2005
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
Try and play it up as a safety issue. Whatever you do, don't be one of those raving lunatics that go in there and scream someone's face off. There's no faster way to make someone stop listening to you.
Old May 31, 2005
red_civic's Avatar
is it with the dealer that I complain with, or is it with Honda Canada?
Old May 31, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
I thought those people always got what they wanted. They shut you up by giving you what you want. Otherwise they think your going to go away quietly. I'd be pissed as heck and made sure they knew it.
Old May 31, 2005
red_civic's Avatar
got the car back today, they told me that water was coming in through one of the floor plugs...Honda Canada issued a Service Bulletin today, in case of other future cases...
Old Jun 7, 2005
zen_master's Avatar
yo, where's that one screw he mentioned on the metal vertical bar???
hmmmmmmmmmmmmm
Old Jul 24, 2005
skratch_munkey's Avatar
skratch_munkey is an unknown quantity at this point
my car is having the same problem. I'm gonna bring it in on monday to see what they can do. I wonder if they'll change the carpet to?
Old Aug 1, 2005
chriscivic's Avatar
chriscivic is an unknown quantity at this point
i think i have the same problem on my 2002 lx sedan. in my passenger floor, i had a big circle of black-green mold that had grown under the floor mat and it was damp, i noticed it when i removed my mats to vacume, but had been smellign something like wet dog, i figured i must have spilt a drink or something but it might be this. i bought some cleaner at wal-mart that said mold and mildew killer and sprayed it on the carpet, after 5 minutes or so the carpet turned a very light beige and looks like crap, does anyone know where i can get new carpet or if honda will replace because of the leak?
Old Aug 1, 2005
chriscivic's Avatar
my car still smells bad
Old Aug 11, 2005
jeremys's Avatar
jeremys is an unknown quantity at this point
Hey tried to perform the above but could not find that pipe. Does this work for a 2002 civic SIG also? I do have a moon roof
Thanks,
Jer
Old Aug 11, 2005
Did any of you guys have water get to the back?
GritzNGravy
Aug 19, 2015 03:03 AM
cukaracha
30
Jul 26, 2015 12:01 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Kyles24
Jul 16, 2015 10:14 PM
Causemo
Jul 5, 2015 06:42 AM
