NEED HELP ASAP!!!!!!!!
Old Dec 22, 2001
WickedExNY's Avatar
WickedExNY is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]I changed my brakes yesterday and its not the first time ive done them...., but so i did what i normally do....now when i drive the car there is a constant popping noise coming from the driver side wheel....im not sure if it could be the camber piston or what. If nebody can give me some suggestions as to what it is it would be greatly appreciated...thanx!
Old Dec 22, 2001
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
When does it make the sound? When you apply the brakes or during normal driving? If it's when you apply the brakes, take them off, reset the piston and re-install them. If it's under normal driving then it might be somthing loose. Other than that I don't know what to say.
Old Dec 22, 2001
Confinement's Avatar
Confinement is an unknown quantity at this point
i had that same problem, except i didnt change my brakes. do you have rims? if you do it could be becasue your lug nuts arent all the way tightened. thats what happened to me and i heard the same thing
