Port and Polish
Old Jan 6, 2005
ajhdragon's Avatar
7thgens official a$$hole
Port and Polish
I was just wonderng if anybody has had a port and polish job done on their 7th gen. I had it done to my old 92z24 and it made pretty nice gains. I was just wondering how a port and polish, and shaving the head down 3mm would do on our cars. i mean its fairly cheap to have done. My machine shop will do it for $200.
Old Jan 6, 2005
allmotor's Avatar
nor cal 7thgens
well gearbox had his head pnp's. You should ask him
Old Jan 6, 2005
zachgeyer's Avatar
sounds sick
Old Jan 7, 2005
I do as do alot of other members. Mine is milled 1mm and has large exhaust ports (too big actually). You want the ports to be larger, but not too big that it will cause backpressure loss. Also don't polish the intake side. The rough bumps are better for airflow. Getting a 5-angle valve job will also help. With my new head done and a few minor mods like ground wires, and header, I made 100whp on my auto ex. Not bad I guess. Gains on a manual would be better. Just make sure to port match a new header so the holes are as large or larger than the head ports you did.
Old May 10, 2005
skydog's Avatar
skydog is an unknown quantity at this point
Hey guys, consider this...
This thing that some people refer to as "backpressure" is a myth! What you really mean to say is that your ports are too big (in diameter) to support a high exhaust gass velocity at lower rpm. A narrrower port makes the gases flow faster, thereby giving the gasses more inertia, and helping the scavenging effect AT LOW RPM. As you move into the engines higher rpm range, you must consider not only the velocity of gasses, but the volume as well. When you start trying to force more and more volume through the ports, the narrower port becomes more restrictive.
Think of two straws of different diameter. If you blow through the smaller one with light pressure, and then on the larger one with the same pressure, the smaller one will have a faster stream of air coming out of it. Now increase the pressure and blow as hard as you can. The smaller straw will become much more restrictive and require more effort, and the larger one will be comparitavely easier to blow through.
Old May 10, 2005
PoorCollegeBoy's Avatar
Stolen digital camera = no ninja picture for me
PoorCollegeBoy is a jewel in the roughPoorCollegeBoy is a jewel in the roughPoorCollegeBoy is a jewel in the rough
^^ I wouldnt call it a "myth" neccesarily, but an overly simple way to look at the mechanics of an engine
Old May 10, 2005
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
well, if you wanted a high-end power car for track racing, larger exhaust ports would be nice. but for a daily driver, you don't want to go too big or you'll lose all the torque for stop-starts. on a race track you usually only need to stop-start once.
Old May 10, 2005
skydog's Avatar
Yo, Ya'll get the idea. Everything is a trade-off!
Old May 10, 2005
S2000man01's Avatar
O RLY
cars DO need a certain amount of backpressure. it is determined by both the intake and exhaust CFM which is dependent upon load and rpm. honda is generally very close to the appropriate amount of backpressure needed for their engines.
Old May 10, 2005
ctv's Avatar
ctv
ctv is an unknown quantity at this point
When I installed my OBX header i took a dremmel to my exhaust ports, and slightly enlarged them, but barly the size of 2 pieces of paper, didnt want to messup too much
the stock exhaust ports are only 1" in Diameter, freakin tiny!
burnyd
ECU Fried
May 24, 2018 10:44 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
99BoostedSi
Sep 7, 2015 04:49 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
Ccoop87
Jul 9, 2015 03:26 PM
