spark plugs
Old Jan 3, 2005
wildstylegraff1's Avatar
wildstylegraff1 is an unknown quantity at this point
spark plugs
i need to know on an 2001 lx do the spark plugs have to be tourqued and is there a way to do it. i've been told to tighten them til they are snug is that true someone help..
Old Jan 3, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Yes they need to be torqued. Usually to 15-18ft/lb.
Old Jan 4, 2005
streetglower's Avatar
you dont need to torque them, I just snuged them up.
Old Jan 4, 2005
WannaBFast's Avatar
Prowlin' with a Purpose
yea.. you gotta torque them.. otherwise they will start loosening.. and eventually fly out the threads and cause some damage
Old Jan 4, 2005
2k3kansasEX's Avatar
Got the broccoli in my back pocket
2k3kansasEX is an unknown quantity at this point
this is funny it is an argument does any one really know for sure lol
Old Jan 4, 2005
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
I think that is EXTREMELY rare... Ok that just will never happen.
The plugs have like 1" of threads on them, They are not going to loosing out that much.
I've alway's snugged them like a drain plug and have never had a problem.
Old Jan 4, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I thought it was 13 foot pounds?
Old Jan 4, 2005
WannaBFast's Avatar
yea im sure that wont really happen with the 01+ civics, but my buddy who has a 97 had his spark plug boot destroyed and it shot up and made a reverse dent in his hood
Old Jan 4, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
as easy as it is to troque it down, i would rather do that than risk any possible damage no matter how remote the possibility may be.
Old Jan 4, 2005
with the spark plugs, once it gets tight, turn it a tad more and thats it.
Old Feb 1, 2005
fastcivic03's Avatar
fastcivic03 should not be trusted
does anyone know where i can buy some spark plugs? for 03 ex
Old Feb 1, 2005
koolaidman's Avatar
koolaidman is an unknown quantity at this point
screw them down by hand then 1/4 turn and ur good...take it from some1 in the field and not a ricer
Old Feb 1, 2005
AlienX's Avatar
AlienX will become famous soon enough
www.sparkplugs.com
Old Feb 1, 2005
I would highly recommend a torque wrench. The plugs are supposed to be a certain distance, so it's important. And I believe it's 13 ft/lbs you want.
Old Feb 1, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Indeed it is.
Doesn't anyone look at the owners manual?
Old Feb 1, 2005
and how many spark plugs do we have to change?
Old Feb 1, 2005
AlienX's Avatar
LOL, what kind of question is that !! HAHA
Old Feb 1, 2005
UTICivic's Avatar
UTICivic will become famous soon enoughUTICivic will become famous soon enough
See, some of us say to torque them, others say that you dont need to.
I can honestly say that just tighten them a bit more than the usual and your good to go. Its really not that big a deal...others are a bit **** about it, but, if you want to torque them...torque them. If you dont want to, then dont. Its really not needed.
Old Feb 1, 2005
UTICivic's Avatar
Old Feb 1, 2005
lol i have no idea bout this topic dont hate jus give me an answer lol
Old Feb 1, 2005
4 FOUR! As in 4 cylinder engine.
Yes you NEED to torque them. Too loose the engine will overheat, too tight and they won't come out next time. Take your chances if you want.
Old Feb 1, 2005
AlienX's Avatar
hahah !!!!!!
Old Feb 2, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
Some cars have four cylinders and more than four plugs.
Old Feb 2, 2005
_Viper_'s Avatar
Yeah Nissans had 8 plugs for their 4 cyl engines,,
truck engines
Old Feb 2, 2005
But civic isn't a truck, it's a car.
Old Feb 2, 2005
tacheon's Avatar
tacheon is on a distinguished road
Torque by definition is a twisting force. So if you are attaching any fastener such as a screw, bolt, or a nut, you are applying torque. Whether it is with your fingers, or a wrench, you apply torque. I believe what everybody is asking is if it needs to be torqued to a specific value. In this case, you would need a torque wrench to measure this torque.
Old Feb 2, 2005
_Viper_'s Avatar
Duhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Old Feb 2, 2005
Jap-Euro Fusion
I had a Nissan Stanza, which is a car (an Altima before there were Altimas if you will). It had a 2.0L 4 banger... it had 8 spark plugs.
Old Feb 3, 2005
masarak's Avatar
master of the culinary martial arts
masarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of lightmasarak is a glorious beacon of light
Here's what NGK's website says:
"Torque is one of the most critical aspects of spark plug installation. Torque directly affects the spark plugs' ability to transfer heat out of the combustion chamber. A spark plug that is under-torqued will not be fully seated on the cylinder head, hence heat transfer will be slowed. This will tend to elevate combustion chamber temperatures to unsafe levels, and pre-ignition and detonation will usually follow. Serious engine damage is not far behind. An over-torqued spark plug can suffer from severe stress to the Metal Shell which in turn can distort the spark plug's inner gas seals or even cause a hairline fracture to the spark plug's insulator...in either case, heat transfer can again be slowed and the above mentioned conditions can occur. The spark plug holes must always be cleaned prior to installation, otherwise you may be torquing against dirt or debris and the spark plug may actually end up under-torqued, even though your torque wrench says otherwise. Of course, you should only install spark plugs in a cool engine, because metal expands when its hot and installation may prove difficult. Proper torque specs for both aluminum and cast iron cylinder heads are listed below."
According to NGK's chart, stock 1.7L Civics have 14 mm thread diameters, so they should be torqued to 18.0~21.6 lb-ft.
Old Feb 3, 2005
That's correct except the torque is 13ft/lbs per the service manual from honda.
