B series engines
if you plan on building internals then just go to the junk yard and get a b18 the only differance on the b18c5 is longer pistons and ish..you can get a vtec head from a 18 or a 16 and build something way better than that b18c5 imo
I need TP for my bunghole
www.ardperfroamnce.com has some good engine deals
direct link to honda engines: http://www.ardperformance.com/cgi-bi...c.pl?serial=25
B18C (1.8 DOHC V-TEC) GSR
Displacement/Valve Layout 1.8 Liter DOHC VTEC (Variable Valve Timing)
Compression Ratio 10.6 :1
Horsepower 178 hp @ 7600RPM
Torque 129 lb-ft@ 6200 RPM
Engine, 5spd, ECU, Harness, Axles, Shift LInkage, and Mounts for $3595.95
Engine, Auto Trans, ECU, Harness, Axles, Shift LInkage, and Mounts for $2295.95
B18C5 (1.8 DOHC V-TEC) Integra Type R
Compression Ratio 10.8 :1
Horsepower 210 hp @ 8000RPM
Torque 134 lb-ft@ 7500 RPM
Engine, Trans, and ECU for $4995.95
to be honest you would be better off prolly going LS/Vtec if your gonna turbo...Your already gonna be doing an asspot of work might as well save yourself some money. Maybe even a b20 Vtec those lil bitches run like a raped ape if tuned right
if your going to turbo, screw both b16a and b18c1 or 5...
save some money and do a b18b. stock it will produce more power than both. then later if you wnat more power, swap heads...
otherwise turboing a b18c like mine is pointless if your going to swap out internals like i am ( haah)...
I agree with gsrchad, the B18B1 is definitely a better choice than the B18C1 or the B18C5 if you want to go the force induction route since it already have a lower compression piston. It's a lot cheaper too to start. The B18C1 & B18C5 are good because of the VTEC & the high compression ratio which high compression ratio engine isn't a good idea to go for force induction.
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
