B series engines
Old Jan 3, 2005
Sc0o73r's Avatar
Sc0o73r is an unknown quantity at this point
Question B series engines
what should i put in to my 96 civic ex?
B18c5
or
B16A2
Also please tell me why you think one is better thatn the other.
Old Jan 3, 2005
Mr.Modify's Avatar
mmmmm b18c5 .....i knew a guy that had one in a hatch. Whooping Vipers and ****....of coursed turboed and stuff.
Old Jan 3, 2005
Sc0o73r's Avatar
ok but is the price difference really worth it?
Old Jan 3, 2005
Mr.Modify's Avatar
hell yea it is ....at least i think it is. Me IMO would pick the b18c5. Depending also on what your gonna do to it to.
Old Jan 4, 2005
Sc0o73r's Avatar
i plan on building internals and then turbocharging it.
Old Jan 7, 2005
mksop's Avatar
mksop is an unknown quantity at this point
if you plan on building internals then just go to the junk yard and get a b18 the only differance on the b18c5 is longer pistons and ish..you can get a vtec head from a 18 or a 16 and build something way better than that b18c5 imo
Old Jan 7, 2005
PunkingCivic's Avatar
I need TP for my bunghole
www.ardperfroamnce.com has some good engine deals
direct link to honda engines: http://www.ardperformance.com/cgi-bi...c.pl?serial=25
B18C (1.8 DOHC V-TEC) GSR
Displacement/Valve Layout 1.8 Liter DOHC VTEC (Variable Valve Timing)
Compression Ratio 10.6 :1
Horsepower 178 hp @ 7600RPM
Torque 129 lb-ft@ 6200 RPM
Engine, 5spd, ECU, Harness, Axles, Shift LInkage, and Mounts for $3595.95
Engine, Auto Trans, ECU, Harness, Axles, Shift LInkage, and Mounts for $2295.95
B18C5 (1.8 DOHC V-TEC) Integra Type R
Compression Ratio 10.8 :1
Horsepower 210 hp @ 8000RPM
Torque 134 lb-ft@ 7500 RPM
Engine, Trans, and ECU for $4995.95
Old Jan 8, 2005
Sc0o73r's Avatar
Thanks guys for all your help. i appreciate it!
Old Jan 8, 2005
sokka7's Avatar
sokka7 is an unknown quantity at this point
http://www.naganojapanese.com/shop_online_honda.html
Old Jan 10, 2005
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
the B18C5 is built for N/A....if you are going to just change out the internals and turbocharge save your money and go with the B16.
Old Jan 11, 2005
incubus7d's Avatar
I Wanna Die Like God on the Cover of Time!
incubus7d is an unknown quantity at this point
B16 and turbo
Old Jan 20, 2005
exturbo6's Avatar
GSR turbo all the way.
Old Jan 20, 2005
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
to be honest you would be better off prolly going LS/Vtec if your gonna turbo...Your already gonna be doing an asspot of work might as well save yourself some money. Maybe even a b20 Vtec those lil bitches run like a raped ape if tuned right
Old Jan 21, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
b18c5 if you can afford it. or a b18c1 if you're on a tight budget
Old Jan 21, 2005
es2's Avatar
es2
bubble party!!!
es2 can only hope to improve
b18c5 w/b16 head
Old Jan 21, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
b18c5 head is a factory ported b16 head
most people use ported b16 heads with b18c1 blocks, which essentially make the "poor man's type r"
Old Jan 25, 2005
gsrchad's Avatar
gsrchad is an unknown quantity at this point
if your going to turbo, screw both b16a and b18c1 or 5...
save some money and do a b18b. stock it will produce more power than both. then later if you wnat more power, swap heads...
otherwise turboing a b18c like mine is pointless if your going to swap out internals like i am ( haah)...
Old Jan 28, 2005
TSSCivic's Avatar
TSSCivic is an unknown quantity at this point
I agree with gsrchad, the B18B1 is definitely a better choice than the B18C1 or the B18C5 if you want to go the force induction route since it already have a lower compression piston. It's a lot cheaper too to start. The B18C1 & B18C5 are good because of the VTEC & the high compression ratio which high compression ratio engine isn't a good idea to go for force induction.
Aball93
May 16, 2015 10:11 AM
krazykoncepts
May 14, 2015 08:18 PM
Pir8pete
Jan 4, 2002 11:25 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
