New Head is on. Whats up with it?
Old Dec 18, 2004
Rufus's Avatar
OK so the new head is on. When I started it the RPM's went right up to 2K after running for about 2 minutes the RPM's started going up and down over and over again. There's a mechanical noise that I can hear too which spooks me out. I didn't drain fluids before I pulled it, but I drained all the oil and flushed it with a quart before I ever even started it. One belt squeals but thats and easy fix. I Zip tied the cam gear to the belt before I ever even pulled the head off so timing should be right on. I know about the Idle learn procedure but the car was off the battery for 12 hours so I'd imagine I don't need to pull the ECU fuse. Any suggestions as to the noise and and the idle? I set all the valves before I put the head on (I'll do it again after it warms up) and I'll flush the anti freeze when it heats up enough to open the thermostat.
Old Dec 18, 2004
dragin's Avatar
dragin will become famous soon enoughdragin will become famous soon enough
hmm. not sure.. got christies on the mind. ahh goin AGAIN tonight, round 8(baseline near az mills)
good luck
Old Dec 18, 2004
ponyman's Avatar
ponyman is on a distinguished road
even with the ECU learn procedure sometimes it still needs to take some time to learn. Mine still took an extra day for the idle to smooth out when I put my TB on so I would give it a day. Also, our cars tend to be a little mechanical sounding. I mean hell my engine has had some wierd mechanical sounds since mile 1 and I have over 25K on it, although I think I have traced it to the PS. I mean it could be anything from parts just needing to reseat themselves after being removed for the pnp job, to a random rattle, I would be inclined to lean away from a mechanical flaw or defect for the time being.
Old Dec 18, 2004
Rufus's Avatar
I've spun 2 sets of rod bearings in my lowered b2000. Knocks scare me.
Old Dec 19, 2004
Rufus's Avatar
Found 2 vacuum lines that were unplugged. Had to get a new power str. belt. Re checked valves and everything runs great. Just raced a early 90's prelude and hung side by side. I think he had more top end cuz he started to pull at about 80. Not much though.
Old Dec 19, 2004
ponyman's Avatar
when are you going to hit the track with it?
Old Dec 20, 2004
Rufus's Avatar
Not sure yet. Threw 2 codes. One for the ECT switch. I think that there's an air bubble in the coolant preventing the thermostat from opening and 2) Vtec system malfunction, could be a few things.
159
Jul 5, 2015 09:54 PM
Sarahwv2910
22
Jun 17, 2015 12:35 PM
alex_nyc
Jun 16, 2015 01:43 PM
hokiedad4
May 3, 2015 10:06 PM
Grey
17
Feb 21, 2004 06:21 PM
