Transmission Slip
Old Dec 8, 2004
hotrodcivic2004's Avatar
my civic has no boost
Exclamation Transmission Slip
I got an 02 ex and i think my transmission is slipping at certain rpms and it doesnt even do it all the time, only when i accelerate slowly. does anyone know what may cause this. my only mods are intake and headers.
Old Dec 8, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
is it when the engine is warm or cold? Do you do any N drops? D3 to D shift?
Old Dec 8, 2004
its hard to say.....it never did it during the summer its only really begun to do it....and yeah i have occasionally. it seems to be moreso when the engine isnt warmed up, but still does it SOMETIMES when it is warmed up.
Old Dec 8, 2004
R1Style's Avatar
Wait... do you have an Automatic or Manual tranny?
If you have a Manual... your clutch is toast. Go get it replaced.
If you have an Auto... take your car to the dealership and have them service it. Your warranty should cover it.
Old Dec 8, 2004
CaliDohBoy's Avatar
CaliDohBoy is an unknown quantity at this point
I have the same problem... usually after having to slow down for some idiot that doesn't know how to drive in front of me then accelerating again. I will notice a :THUNK: when it down shifts from 2-1. I'm not sure what the cause is. It has bugged me for awhile now... I just feather the gas after having to brake like that now.
Old Dec 8, 2004
yeah calidohboy thats wut happens to me too...and when i accelerate slowly its from 2-3 usually it reves then :thunk: into 3.....yes its an auto
Old Dec 11, 2004
sohcvtec2001ex's Avatar
sohcvtec2001ex is an unknown quantity at this point
hey guys if you have a auto trans get it into a shop now your trans is ate up on the in side i let go to long and had to buy a new trans a nwe fornt drive axel and a trans mount so get it fixed now
trans = transmission my cost was $2700
Old Dec 11, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Suggestion: Get a fluid change first. Look for excessive metal in the fluid. There will always be SOME. If the fluid seems normal, fresh fluid may cure it. If it has a lot of metal in it..... well, the tranny could be on it's way out.
Old Dec 12, 2004
SOHCD17's Avatar
SOHCD17 has a little shameless behaviour in the past
ok another tranny question...i got a 01 civic lx MT and when im in 2nd gear turnin, it throws itslef out of gear..and when im changing to 2nd, sometimes it jus grinds...
if i was to get a short shifter will that still happen..help me out...thanks
Old Dec 12, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
NOOOOO, that is how your auto works you guys!!!!!!!!!!!!!! hotrod bring it over and I will give it a go, it is fine trust me
Old Dec 12, 2004
bgoetz's Avatar
if your tranny was slipping you would be posting my tranny slipping. you would know it
Old Dec 12, 2004
bgoetz's Avatar
yep that is bad syncros or many other possible problems at work. A short shifter does nothing but shorten what you have up
Old Dec 12, 2004
SOHCD17's Avatar
ya i was thinkin that...well thanks 4 letting me no bout the short shifting
Old Dec 12, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
question.. what exactly does a slipping tranny sound like? I've been boosting my auto around 4psi, and sometimes when going from 1st to 2nd and 2nd to 3rd, if i don't release the gas at the shift point, the RPMs will quickly spike to about 5k then it shifts after half a second. there isn't any kind of jerking or grinding, just a rev then a smooth shift. this only happens with those 2 gears, and only if I am at or above 3k RPM, or 2-3psi+ when the car shifts. this started (or at least i first noticed it) about 2 weeks after i started boosting, but lately it doesn't seem to happen as often, if at all. maybe it fixed itself?
Old Dec 12, 2004
so then what is goin on with my transmission! its not serious?
Old Dec 12, 2004
Well unless the rpms are actually revving up before it shifts, you should be fine. If that's happening, usually one day it just won't go into gear anymore.
Old Dec 12, 2004
bgoetz's Avatar
I really don't think so I would have to drive it, but it does not sound that way
Old Dec 12, 2004
hey hotrodcivic get your car into the shop and have them look at it it might be serious it might not. sounds like your trasnmission was like mine and it was serious. GET IT INTO THE SHOP
Old Dec 12, 2004
HEY HOT RODCIVIC get your car into the shop it sounds like the same thing my civic was doing it was not good when i heard frome the shop so get in. my transmission was ate up on the inside my front trans axel and transmission mount was broke
Old Dec 12, 2004
did your warranty cover it
Old Dec 13, 2004
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Yes, typically in all automobiles when you have a spike in RPMs between gear changes in an automatic transmission then yes it is slipping.
Old Dec 13, 2004
yeah but mine doesnt spike that dramatically.......between 2-3 it'll disingage 2nd gear.....rev up 2-300 rpm.....then engage 3rd.
Old Dec 13, 2004
SMX's Avatar
SMX
SMX is on a distinguished road
It's all in how the trans is programmed to shift. They come from the factory with a relatively smooth shift 'cause that's what most folks want. My c-6 is highly tweaked and shifts like a ton of bricks, no pause, just instant shift with a bang and tire chirp.
In your case, the extra power is stressing the trans and the bands don't sound like they are holding like they should during the shift. You might try swapping your tranny fluid for some Redline. That may tighten it up enough. If not, you need to take it to someone that knows how to tune honda transmissions.
Old Dec 13, 2004
hey hotrodcivic2004 no my warranty did not cover it to many miles but you better get your car in and have them look at it
Old Dec 13, 2004
Zzyzx's Avatar
Autocross Junky
I had that problem exactly, had to take a tech with me and drive around to prove it though... Honda Warrantyed the work, Replaced the 2nd and 5 gears + synchros.
Old Dec 14, 2004
SOHCD17's Avatar
ZZYZX....hey man thanks alot imma have 2 let them no the deal...how long they take ur baby away from u...hopefully not more the a week...i cant live with out my car...thanks
Old Dec 16, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
This happens to me as well. i have a 2001 EX coupe Auto. This feels to be the case mostly if the engine is cold. But i plan on changing the ATF again soon. I changed it once already with Mobile 1 at around 20,000 miles. I hope it fixes itself.
Old Dec 17, 2004
hey man i strongly reccomend going to honda and getting their ATF-Z1 oil, i've heard horor stories of aftermarket transmission oil. motor oil is one thing but the tranny is a whole diff. story. it is a tad pricey though i just got mine for 4.16 an quart i think.
dantheman42
Sep 4, 2015 01:10 PM
xeroid
Aug 31, 2015 10:53 PM
JetsterDajet
Aug 15, 2015 08:07 AM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Jul 12, 2015 11:54 AM
