cut bumpstops or cut the rubber on the dust covers?
Old Dec 2, 2004
slicksivik's Avatar
inputs appreciated, some say dust covers and others might say its the hitting of the bumpstops. and yea i researched and searched for all the info and its differeing. just wondering whats better, cuz im getting it done tomorrow morning. they said if they cut the bumpstops it would bottom the car out and it would cause it to hit the body. if i cut the dust boot covers, they said it mght lower the car. is this right or are they wrong. im confused, someone enlighten me. oh and yea, the problem i have is this noise when ig o over dips and bumps on the right side only. they said they have to cut both sides, not just one side. and yea, before they took some oil or something and they sprayed all the bearings and stuff and most of the noise went away for like a day. so does that mean its not the dust boot covers and its something else or is it? thanx.
Old Dec 2, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
The dust boot isn't holding anything up... so cutting it won't lower the car. Don't cut the bumpstops.
PS- if the shop is that dumb, find a different one.
Old Dec 2, 2004
prccivic's Avatar
why shouldn't you cut bumpstops?
Old Dec 2, 2004
PunkingCivic's Avatar
I need TP for my bunghole
the bump stops keep the pistion of the shocks/struts from completely bottoming out
Cutting them could totaly fudge them up if you ever bottom out.
the bump stops are a safe guard.
Old Dec 2, 2004
robbclark1's Avatar
Retired suspension supermod.
It is suggested to cut the bumpstops on some coilovers, but are you cutting the stock bumpstops? I would suggest not to. However, boilermaker is right, it won't lower your car any.
Old Dec 2, 2004
slicksivik's Avatar
so keep bumpstops and cut dust boot?
Old Dec 2, 2004
slicksivik's Avatar
im guessing stock bumpstops cuz i got b&g's, but shouldn't u cut the dust boot? im confused still, lol, pics!
Old Dec 2, 2004
alot of peeps with the coil over were saying that the dust cover can rub on the body of the coilovers and make noise. So to combat that some people cut the dust covers a little.
Old Dec 2, 2004
flotsamm's Avatar
Go by what the manufacturer recommends. For example, Goldline recommends you trim the bumpstop. If you dont, you'll bottom out on the bumpstop. For my Eibach sportlines I trimmed mine down an inch.
Old Dec 3, 2004
Danka02's Avatar
SICCMADE
Danka02 is an unknown quantity at this point
/\/\ same here
Old Dec 6, 2004
slowvic's Avatar
slowvic is an unknown quantity at this point
With sportlines and either tokicos or stock struts, the car will rest on the front bumpstops constantly if they are not trimmed. I think it is best to trim.
Old Dec 6, 2004
2K1Civic17"Gabe's Avatar
yeah, my goldlines installation paper said to trim bumpstop 1" fr, and 1.75" rr, could be the other way around. Some vehicles you are not supposed to trim them, but with ours you are supposed to for most setups I believel I also have tokico HPs, and the directions said do not cut bumpstop, but the goldlines said to, so I did. Works perfect.
Old Dec 7, 2004
infinite's Avatar
infinite is an unknown quantity at this point
i'm on neuspeed sports and my front end is constantly resting on my oem bumpstops. i didn't hear it in the summer but now that it's freezing out the cold must have stiffened the rubber and it squeaks. i know because i can hear them compressing, making an annoying rubberish squeaking noise when i go over speedbumps or inclines. i need to trim them this summer. is it ok to drive like this? it's not going to damage my suspension is it?
Old Mar 3, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
bring this one back to life!! ..bump. ^ i wanna know the answer to that question too
Old Mar 3, 2005
nitroal1973's Avatar
Broken Road......
nitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to allnitroal1973 is a name known to all
I have Eibach Pro Kit, and did not cut anything. I haven't had any problems so far.
Old Mar 3, 2005
SevenCyrus's Avatar
Se7enCyrus Racing/Motorsports
SevenCyrus will become famous soon enoughSevenCyrus will become famous soon enough
I got Nuespeed race, it just says to trim rears 1.25". The bump stops are on top of the strut right? Thanks And should i do front?
juror
Suspension DIY
Jul 30, 2019 03:28 AM
BootyDo
Jul 7, 2015 06:06 AM
