springs with stock shocks?
Old Nov 21, 2004
kkk's Avatar
kkk
kkk has a little shameless behaviour in the past
heylo all .
i have owned 3 different cars . and have alwaz altered factory springs to make then small (2.5" drop). but all my rides have been really bad! . road back here are really bad with big holes and bumps every where .
now i plan to sell my 2004 civic and get a 2005. now my question is
1) wat if i get branded springs from a repectfull company ? will my ride be as rough as wat currently i have?
2) if i alter the springs , wat should b the max drop which would give me more comfy ride? currently i have been dropping them 2.5 " .
thanx
Old Nov 21, 2004
robbclark1's Avatar
Retired suspension supermod.
http://www.7thgencivic.com/forums/fa...s#faq_susp_faq
read the FAQ
Springs aren't the only determinate of a comfy ride. Your ride quality on your past cars has been shity because 1) you altered stock springs and 2) you didn't get better shocks. Anytime you lower you will lose ride quality. Do not alter you stock springs by cutting or heating because that can be very dangerous. You can go as low you as want, but I don't suggest going lower than 1" on stock shocks. You need to get better shocks. Even if they are brand springs, the ride will still be shitty on stock shocks and you run the risk of blowing them. Before you do anything, research! Suspension keeps your car on the road. You fvck with it the wrong way, you can end up in a ditch or wrapped around a light pole. Either do it the right way or don't do it at all.
Old Nov 21, 2004
shmik1's Avatar
^^^ I agree, who the hell cuts springs.. I know tons of people do, but thats rediculous imo..
Old Nov 22, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
whats with the username? eH
Old Nov 22, 2004
nikoscivicex's Avatar
www.8thgencivics.com
nikoscivicex is an unknown quantity at this point
^ i already asked that question awhile back... he says it has something to do with his name but????
Old Nov 22, 2004
Zzyzx's Avatar
Autocross Junky
Robbclark has it right...
I'd say that you've ran in to 3 things on your privious cars..
1. Soft spring rates (Cut OEM springs) and a low ride height = Bottoming out alot = Poor ride quality and Handling issues.
2. Too Low of a ride height = poor suspension geometry = Poor ride and handling Characteristics.
3. OEM shocks on a lowered car = Blown shocks = Poor ride quality and Handling Issues.
So, what this tells you is A. the lower you drop the car, the higher the spring rates neede to stop the car from bottoming out. B. There is very much a thing as too low. and C. Most cars come from the factory Under dampend, as it makes for a softer ride. take those soft shocks and make them work in a range they werent designed to = blown or weaker shocks.
So what you need Is a decent spring rate and some good shocks.
Old Nov 25, 2004
MyK's Avatar
MyK
MyK has a little shameless behaviour in the past
KKK,
I suggest you simply remove the shocks from your car and cut your springs down to two rings. this will give you the comfy low ride you want over all them big ole holes and big *** bumps.
do it. trust me!
Old Nov 26, 2004
Ershall's Avatar
Ershall is an unknown quantity at this point
Originally Posted by MyK
KKK,
do it. trust me!
Yes, in fact, springs? what springs!? you don't need no springs son!
Old Nov 26, 2004
D17thgen's Avatar
KKK,
do it. trust me!
wow... what an jerk..
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
Jul 12, 2015 11:54 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
