Lx to Ex header/cat conversion
Old Nov 7, 2004
Stratablak314's Avatar
Stratablak314 is an unknown quantity at this point
Ok.. I know this has to be somewhere on the site but I've searched over and over again and cannot find anything about it. I have an Lx and i want to re-locate the cat so that i can put on a cat-back exhaust that is made for Ex's. Anyone have a link to some info or a DIY on the site?
Old Nov 7, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
Basically all ya need to do is get an aftermarket header for an ex, megan racing downpipe (for ex), and ur good to go. Ya might have to custom fab a hanger for the downpipe.
Old Nov 7, 2004
takumi's Avatar
takumi is on a distinguished road
Just buy the Tanabe exhaust adapter.
Old Nov 7, 2004
Boosting Daily
/\/\agreed, this would be cheaper
Old Nov 7, 2004
Thanks guys...i'll probably go with the Tanabe thing, but do you think i should just get a custom exhaust built instead of paying over 600 for the Tanabe adapter and then the Exmag?
Old Nov 8, 2004
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
you should convert it to the ex exhaust cause your engine will "breathe" better. the cat on the lx is really restrictive and the pipe is soooo small. and you could spend less than $600 doing it too....ebay it.....lol. a custom full exhaust will be really expensive, but a cat-back wouldn't be too bad. but if you just do a cat-back, you really aren't helping much cause of the header and cat suck.
Old Nov 9, 2004
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
I got megan racing ex header, hi flow cat, and catback exhaust for less than $600 on ebay. My signature proves the results.
Old Nov 9, 2004
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
But will the EX header bolt directly up to the lx head? I seem to recall reading somewhere you had to modify the header to some extent for it to install properly. I have been contemplating this swap myself for a while.
Old Nov 9, 2004
bradmanuwf's Avatar
It will bolt up, the only big difference in LX is not VTEC. There are other differences too but I'm not going to get into those. You'll probably have some trouble with the exhaust hangers though. You'll have to take it to the shop to get it all put on and positioned properly, and I'm not sure about the O2 sensor wire length too.
Old Nov 9, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
i have a ex stock down pipe if u need
Old Nov 10, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
IMHO keep spending your money on the cheap stuff whilst after i save and rape ur booties with a custom turbo.
Old Nov 10, 2004
Boosting Daily
/\/\was that really nessesary?
Old Nov 10, 2004
LiKEaFeRiO's Avatar
I think the Ex has 1 sensor while the Lx has 2?
Someone find out.
You'll have to lengthen the O2 sensors or buy a simulator if you care about keeping your CEL off.
Old Nov 10, 2004
bradmanuwf's Avatar
the EX has two sensors also. All OBD-II engines have two O2 sensors. Eternalblue_Vic is right. was that really nessesary lkm. I have my turbo kit and the "cheap stuff" so what's up now. As soon as my oil pan gets here, the turbo is going on. you have to start somewhere, and the "cheap stuff" is the best place. unless you have a **** load of money to blow.
Old Nov 12, 2004
lkm,
I'm f-in 18 and have a part time job... where the hell am i supposed to get an endless supply of money? If i was rich i wouldn't own a civic dumb azz.
Anyways... back to the main subject... everyone agrees that the whole ex switch is far more superior to the tanabe adapter?? I'm gonna need the ex header, downpipe, and cat from an ex (or FOR an ex if you go aftermarket) and then some other minor stuff? And THEN an exhaust system.. haha the spending never stops!!!
Old Nov 12, 2004
CdKoInU's Avatar
CdKoInU is an unknown quantity at this point
dont you also need an ex front sway bar cuz the cat would not clear an lx's???
Old Nov 13, 2004
PrecisnTec's Avatar
Originally Posted by Stratablak314
lkm,
What was said here and in other threads, you will need the Exhaust Manifold, Mid-pipe/Cat, and either the cat Back exhaust from the stock Ex or buy an aftermarket cat back exhaust. And you will probably have to let an exhaust shop install most of it for you as the mounting points for an ex exhaust and the dx/lx are not the same.
Yes, that too.
BJB
Sep 14, 2015 11:16 PM
tomas6791
Sep 11, 2015 06:47 PM
Pier7866
Sep 6, 2015 06:54 PM
Broadbeb
May 14, 2015 09:49 PM
VanDizKo
Feb 12, 2002 08:48 AM
