Throttle Cable Installation who has done it?
Old Oct 31, 2004
dubz01si's Avatar
dubz01si is an unknown quantity at this point
Friday Evening after work going to the bank i pull out from work on to the busy rd. my pedal goes right to the floor i knew i snaped the cable from the pedal, who knows how this is to intsall ? and how hard will it be i hope i can do it myself?
Help Plz any suggestion's ,,,,, the good thing is the part was only 11.00CND
Old Oct 31, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
Hmm... Shouldn't be too hard.. All you need to do is connect the cable to the gas pedal and then the the throttle thingy... I forget what its called. lol. But its going to be a bitch working in the space that it gives you to work in.
Old Oct 31, 2004
dubz01si's Avatar
as long as i dont need much Tools i wont have any it will be all tight fitment with the very small Area it gives me.
Old Oct 31, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
same thing happened to me when i installed my intake if the cable isnt broken u just have to plug it back on, its easy. if you have the stock airbox on u might wanna take that out because it will b hard to do it with that on.
Old Oct 31, 2004
exclusive_vtec's Avatar
happened to my friend this friday... he was revin the engine.. and it sliped we just placed it back on.. it and it worked...
Old Nov 1, 2004
Blahman2's Avatar
yea it slipss off if you rev your engine from under the hood... Its a bitch cause you don't realize it until you get in the car and try to drive it.
cukaracha
Jul 7, 2015 05:50 PM
Shakzhussain
May 17, 2015 12:03 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
1stcivic
Nov 18, 2001 09:17 PM
silvercallx
Aug 31, 2001 07:56 PM
